Access-List Blocking Access
Create Share
Level 3
Level 3
Hi!
After adding the below Extended Access-List Entry into my 1841 Router,
access-list 102 permit ip host 192.168.1.1 any
i can access the Internet from this client but cannot connect to this client from another branch through vpn tunnels. I can access all other clients that do not have this access-list entry.
Thanks.
5 Replies 5
John Peek
Level 2
Level 2
Posting your config will help.
Current configuration : 1934 bytes
version 12.4
hostname Branch-Router
boot-start-marker
boot-end-marker
no logging buffered
no logging monitor
enable password password
no aaa new-model
resource policy
mmi polling-interval 60
no mmi auto-configure
no mmi pvc
mmi snmp-timeout 180
ip subnet-zero
ip cef
no ip dhcp use vrf connected
ip name-server Server-1
ip name-server Server-2
vpdn enable
vpdn ip udp ignore checksum
vpdn-template 1
vpdn-group 1
! Default PPTP VPDN group
accept-dialin
  protocol pptp
  virtual-template 1
username vpn password 0 vpn
interface Tunnel1
description VPN To Main-Office
ip address 192.168.100.2 255.255.255.0
tunnel source router wan ip
tunnel destination main-office router wan ip
interface FastEthernet0/0
description WAN
ip address public ip
ip nat outside
duplex auto
speed auto
interface FastEthernet0/1
description LAN
ip address 192.168.1.2 255.255.255.0
ip nat inside
duplex auto
speed auto
interface Virtual-Template1
ip unnumbered FastEthernet0/1
peer default ip address pool branch
no keepalive
ppp authentication pap chap ms-chap
ip local pool  192.168.1.101 192.168.1.150
ip classless
ip route 0.0.0.0 0.0.0.0 router wan ip
ip route Main Office router wan IP and mask Tunnel1
no ip http server
ip nat pool ovrld public ip public ip prefix-length 30
ip nat inside source list 102 pool ovrld overload
control-plane
line con 0
password password
login
line aux 0
line vty 0 4
password password
login
line vty 5 15
password password
login
end
You will need to NAT exempt the traffic from 192.168.1.1 going to the IP's on the other end of the tunnel , so if your other end IP subnet is for ex 10.0.1.0/24 then you will need to modify the access list 102 like :-
access-list 102 Deny ip host 192.168.1.1 10.0.1.0 0.0.0.255
make sure the NAT exempt statement appears before the permit any statement.
Manish
Tried but did not succeed. There may be other things that need to be blocked.
Any Suggestions?
Thanks.
access-list 102 Deny ip host 192.168.1.1 SOURCE_IP WILDCARD_MASK
are you sure that you have right SOURCE_IP & WILDCARD MASK ?
Try wireshark/tcpdump on 192.168.1.1 and capture the source ip coming in and then deny that in your NAT access-list 102.
Manish
