Access List deny ip in same vlan
Nuno Castro
Hello all;
Here is my configuration:
Building configuration...
Current configuration : 2421 bytes
version 12.4
no service pad
service password-encryption
hostname NAME
boot-start-marker
boot-end-marker
logging message-counter syslog
aaa new-model
aaa authentication login default local
aaa authentication ppp default local
aaa authorization exec default local
aaa session-id common
dot11 syslog
ip source-route
ip dhcp excluded-address 10.0.0.1 10.0.0.10
ip dhcp pool lan
   import all
   network 10.0.0.0 255.255.255.0
   dns-server 8.8.8.8
   default-router 10.0.0.254
   lease infinite
ip cef
ip name-server 192.168.1.254
vpdn enable
vpdn-group 1
! Default PPTP VPDN group
 accept-dialin
  protocol pptp
  virtual-template 1
archive
 log config
  hidekeys
ip ssh time-out 60
ip ssh authentication-retries 2
interface ATM0
 no ip address
 shutdown
 no atm ilmi-keepalive
interface FastEthernet0
interface FastEthernet1
interface FastEthernet2
 switchport access vlan 2
interface FastEthernet3
interface Virtual-Template1
 ip unnumbered Vlan1
 peer default ip address pool VPN
 no keepalive
 ppp encrypt mppe auto required
 ppp authentication ms-chap-v2
interface Vlan1
 description *** INTERFACE OUTSIDE ***
 ip address 192.168.1.254 255.255.255.0
 ip nat outside
 ip virtual-reassembly
interface Vlan2
 description *** Client Network ***
 ip address 10.0.0.254 255.255.255.0
 ip access-group 101 in
 ip nat inside
ip local pool VPN 192.168.1.50 192.168.1.60
ip default-gateway 192.168.1.1
ip forward-protocol nd
ip route 0.0.0.0 0.0.0.0 192.168.1.1
no ip http server
no ip http secure-server
ip nat inside source list NET interface Vlan1 overload
ip access-list extended NET
 permit ip 10.0.0.0 0.0.0.255 any
access-list 101 deny   ip any 192.168.1.0 0.0.0.255
access-list 101 deny   tcp any 192.168.1.0 0.0.0.255
access-list 101 deny   udp any 192.168.1.0 0.0.0.255
access-list 101 permit ip any any
control-plane
line con 0
 no modem enable
line aux 0
line vty 0 4
 password 7 XXXXXXXXXXXXXXXXXX
 transport input ssh
 transport output all
scheduler max-task-time 5000
end
Now i want to deny ip traffic between any host in vlan 2, except the range 10.0.0.0.1 to 10.0.0.10. Can you help me?
Best regards
5 Replies 5
Julio E. Moisa
I think you could use private vlans to complete that.
http://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst3560/software/release/12-2_52_se/configuration/guide/3560scg/swpvlan.html
>> Marcar como útil o contestado, si la respuesta resolvió la duda, esto ayuda a futuras consultas de otros miembros de la comunidad. <<
Does this work for any Switch or Just L3 ones? I tried it in some 2960 I got here and no-one has this functionality.
I recommend to verify the Cisco compatible tool (http://cfn.cloudapps.cisco.com/ITDIT/CFN/jsp/index.jsp) with your IOS also please see the following link:
http://www.cisco.com/c/en/us/support/docs/switches/catalyst-6000-series-switches/10601-90.html
Hello;
Thanks a lot for your answer.  My router is an old one Cisco 877, with c870-advsecurityk9-mz.124-24.T8. I can't have private vlans in this IOS Version, can i deny traffic with access lists?
Best regards;
I am not sure if your 877 supports Vlan Access Lists. Try the config below (in this example, host 10.0.0.11 cannot talk to anyone, the rest can. If this works, we can add all the other hosts as well, with some address summarization):
877(config)#access-list 101 permit ip host 10.0.0.11 any
877(config)#vlan access-map DENY_RANGE 10
877(config-access-map)#match ip address 101
877(config-access-map)#action drop
877(config-access-map)#vlan access-map DENY_RANGE 20
877(config-access-map)#action forward
877(config)#vlan filter DENY_RANGE vlan-list 2
