Access list issue in isp enviroment
m_aurangzeb
presently i m working in ISP and eventually i felt that access list is too heavy and also our system engineer give me suggestion to light weight the access list. in our access list by default all users are allowed all and few ports are closed. what is the other way that can light weight the acces list.please tell me the suggestion what consideration should be kept into mind before i light weight ACL .In ISP different users use diffrent applications and thus they use almost all ports.so how should i implement access list in this situation.
is it possible to post the access list ? If that is a problem, you could blank out all IP addresses and confidential information...
Keep in mind the following rules and best practices when it comes to access lists:
- the access list is always checked top down, that is, when a match is found, no further checks are done. That means that you should put frequently used access list statements at the top of your access list
- the shorter the access list, the better for the performance and throughput. Try to summarize statements as much as possible
As said before, it would be best if you could post the access list you need to modify.
GP
i ll post it after few moment, thanx for suggestion.
thanx GP
access-list 1 permit src_IP
access-list 2 permit src_IP
access-list 3 permit any
access-list 101 permit ip host src_IP any
access-list 101 permit ip any host host_IP
access-list 101 deny icmp any any redirect
access-list 101 deny tcp host host_IP any eq 443
access-list 101 deny icmp host host_IP any
access-list 101 deny tcp any dst_IP eq finger
access-list 101 deny tcp any dst_IP eq nntp
access-list 101 deny tcp src_IP eq uucp
access-list 101 deny tcp src_IP login
access-list 101 deny tcp any dst_IP eq whois
access-list 101 deny tcp any dst_IP eq 42
access-list 101 deny tcp any dst_IP eq 445
access-list 101 deny tcp any dst_IP eq 135
access-list 101 deny tcp any dst_IP eq 137
access-list 101 deny tcp any dst_IP eq 138
access-list 101 deny tcp any dst_IP eq 139
access-list 101 deny tcp any dst_IP eq 1434
access-list 101 deny tcp src_IP any eq 445
access-list 101 deny tcp src_IP any eq 135
access-list 101 deny tcp src_IP any eq 137
access-list 101 deny tcp src_IP any eq 138
access-list 101 deny tcp src_IP any eq 139
access-list 101 deny tcp src_IP any eq 1434
access-list 101 deny udp any dst_IP eq 445
access-list 101 deny udp any dst_IP eq 135
access-list 101 deny udp any dst_IP eq netbios-ns
access-list 101 deny udp any dst_IP eq netbios-dgm
access-list 101 deny udp any dst_IP eq netbios-ss
access-list 101 deny udp any dst_IP eq 1434
access-list 101 deny udp src_IP any eq 445
access-list 101 deny udp src_IP any eq 135
access-list 101 deny udp src_IP any eq netbios-ns
access-list 101 deny udp src_IP any eq netbios-dgm
access-list 101 deny udp src_IP any eq netbios-ss
access-list 101 deny udp src_IP any eq 1434
access-list 101 deny tcp any dst_IP eq 4444
access-list 101 deny tcp any dst_IP eq uucp
access-list 101 deny tcp any dst_IP eq login
access-list 101 deny tcp any dst_IP 0.0.255.255 eq 4444
access-list 101 deny ip host 0.0.0.0 any
access-list 101 deny ip src_IP any
access-list 101 permit ip any any
access-list 102 deny ip src_IP any
access-list 102 permit ip any any
access-list 103 deny icmp any host host_IP
access-list 103 deny ip any host host_IP
access-list 109 deny ip any host host_IP
priority-list 1 protocol ip high tcp 1720
priority-list 1 protocol ip high tcp 1503
priority-list 1 protocol ip normal udp domain
priority-list 1 protocol ip normal tcp www
