Access list reducing
I am an IT guy owned a company with 25 branches
I have take two links from two service providers and i did a policy based routing
In HQ router, i applied the PBR as follows
track 1 ip route 1.1.1.180 255.255.255.255 reachability
delay down 5 up 5
interface GigabitEthernet0/1
ip address 192.168.100.198 255.255.255.0
ip policy route-map PBR
duplex auto
speed auto
standby 10 ip 192.168.100.199
standby 10 timers 1 15
standby 10 priority 150
standby 10 preempt
standby 10 track 2 decrement 100
ip access-list extended PBR-SP1
permit ip 192.168.100.0 0.0.0.7 192.168.180.0 0.0.0.255
permit ip host 192.168.100.8 192.168.180.0 0.0.0.255
permit ip host 192.168.100.9 192.168.180.0 0.0.0.255
permit ip host 192.168.100.160 192.168.180.0 0.0.0.255
permit ip host 192.168.100.180 192.168.180.0 0.0.0.255
deny ip any any
route-map PBR permit 10
match ip address PBR-SP1
set ip next-hop verify-availability 192.168.100.197 1 track 1
Track object is to check the availability of a particular branch (192.168.180.0/24)
Since i need to track other 3 branches as well, i will input them in route-map PBR 20,30,40 ..... sequences
Then i will need create following
1. 23 track objects
2. 23 ip access-lists
Is it OK to do that with the router??? will that cause any issue related to router performances ??
My router is cisco 1941
Philip D'Ath
I think you might be doing this the hard way.  Have you considered using EIGRP and OTP (Over The Top)?
http://www.cisco.com/c/en/us/products/collateral/ios-nx-os-software/ip-routing/whitepaper_C11-730404.html
Basically you configure static EIGRP neighbours on each wan, and then specify "lisp-encap" and EIGRP will automatically tunnel the packet.  The service providers don't have to know anything about your routing and vice versa.  You can then use EIGRP metrics to control which path is used.   Failover is all automatic.
neighbor A.B.C.D <WAN-intf> remote <2-100> lisp-encap [1-1999]
If that is all a bit scary you could also use plain multipoint GRE tunnels to do the same thing, one for each service provider, and EIGRP to dynamically failover and select the routing path.
I think GRE is OK. But how i will fulfill my requirement with GRE???
I think you haven't understood my question
Philip D'Ath
If you are still keen on using route tracking combine it with IP SLA.  Check out this article:
https://supportforums.cisco.com/document/30296/using-ipsla-change-routing
Thanks for this
This is not suited for this since the requirement is complex in this one
