ASR 9900 factory reset
willicac54
Hi all,
Does anyone know how to reset a ASR 9900 to factory defaults?
Thanks!
Vinit Jain
You can try using the command "commit replace best-effort". This should help reset the configuration on the router.
Vinit
--Vinit
