Access-list statement format, help!
richarddowna
Hello
Im rather confused at a few statements with access-lists.
Mostly about the source and destination parts of the commands.
access-list 101 permit tcp 192.168.27.0 0.0.0.255 host 192.168.30.3 eq telnet
access-list 101 permit tcp <?source ip and wildcard mask?> host <?destination ip?> eq telnet
     Q1. Is the above correct? And what does eq mean?
access-list 101 deny ip 192.168.27.0 0.0.0.255 192.168.30.0 0.0.0.255
access-list 101 deny ip <?source ip and wildcard mask?> <?destination ip and wildcard mask?>
     Q2. Is the above correct?
access-list 111 deny ip any any
access-list 111 deny ip <?source?> <?destination?>
     Q3. Is the above correct?
access-list 121 permit tcp any host 192.168.30.3 eq www
access-list 121 permit tcp <?source?> host <?destination?> eq www
     Q4. Is the above correct?
Thankyou!
Hi Richard,
access-list 101 permit tcp host eq telnet
     A:  It means that 192.168.27.0/24 network is allowed to access host-192.168.30.3 only TCP/Port-23 aka Telnet.
    A:  Correct
     A:  Correct , Note: Keep in mind , there is an implicit deny at the end of statement of ACL.
access-list 121 permit tcp host eq www
     A:  Correct , It's the same logic as ACL 101
Rgds,
Toshi
5 Replies 5
Hi Richard,
    A:  Correct
Rgds,
Toshi
Another thing,
Since the order that ACL is input matters,
Do I need to remake the entire access-list if I need to insert a rule?
Seems kind of annoying? Is there a way to insert ACLs into correct place?
Hi Richard,
      I used to use a notepad to re-order IP access-list in the old IOS verstion. In the new IOS version,we are now lucky. You can use the following commands.
Router#sh access-list 101
Router#conf t
Router(conf-t)#ip access-list extended 101
Router(config-ext-nacl)#?
F.e.
Router(config-ext-nacl)#no 10
Router(config-ext-nacl)#11 access-list 101 permit tcp 192.168.27.0 0.0.0.255 host 192.168.30.3 eq telnet
Hope this help
Toshi
Very helpful.
Thank you!!
cadet alain
Hi Richard,
Q1: yes and eq means equal and the number following is the destination tcp/udp port( or well-known name of service)
Q2: yes
Q3: yes
Q4:yes
Regards.
Alain.
