Access Server 2511 urgent Help needed
newnetman
Hello All,
In an attemp to upgrade/install my AS, it took me to the shown interface instead of ROMMON,how can i get out of this interface to proceed with the installations?. The underlisted is all that shows up now when the router boots.
Thanking you all in advance
System Bootstrap, Version 11.0(10c), SOFTWARE
Copyright (c) 1986-1996 by cisco Systems
2500 processor with 14336 Kbytes of main memory
7 Replies 7
Edison Ortiz
You are in Rommon, please see:
http://www.cisco.com/en/US/products/hw/routers/ps233/products_tech_note09186a008009464c.shtml
HTH,
__
Edison.
Please rate helpful posts
Many thanks for your response. Unfortunately the the command was rejected.
Here is the outcome
>o/r 0x2102
What?
Your further assistance shall be appreciated.
Have you tried typing 'i'
>i
What do you get?
You have to be careful, any space, though not shown will produce an incorrect command. Make sure you've typed
>o/r 0x2102 without hitting a back space and trying to delete something.
__
Edison.
Thank you again sir, It's becoming very strange though, after typing the last command o/r 0x2102 the system came up with "what?" and ever since it does not even accept any further command.
No key pressed is further displayed. My terminal setting is 9600,8,N 1
Hope i can still be helped further?.
If you are unable to type anything, I don't know what else to tell you.
Try rebooting the router and see if you can perform a ctrl+break sequence.
__
Edison.
Hello, thanks you so much for your time. After rebooting the system, it now accept the commands o/r 0x2102 followed by letter "i" and now brought me to the following prompt
Copyright (c) 1986-1996 by cisco Systems, Inc.
Compiled Fri 27-Dec-96 17:33 by loreilly
Router(boot)>
Your further assistance awaited
Go back and read the link I provided, it will instruct you on how to load the IOS by using TFTP.
__
Edison.
