Access to published server from NAT on the same router?
Ivanleonel
I have ISR router and published server (static NAT). Server’s FQDN server.domain.com
Also, this router has a wi-fi network with NAT pool.
If wi-fi clients try to connect to server.domain.com connection doesn’t work because of resolving to server’s public IP.
I don’t want to use split-dns.
I’m thinking about PBR + next hop to ISP’s gateway, but not sure about this solution.
Are there any options?
Hello
If you wish to access the server via the public ip address then try the following
Example - Nat hairpinning:
int loopback 100
description Nat_pin
ip address 169.254.1.1 255.255.255.255
ip nat inside
ip access-list extended 110
remark global nat access-list
5 deny ip 192.168.1.0 0.0.0.255 192.168.1.0 0.0.0.255
ip access-list nat-pinning
permit ip 192.168.1.0 0.0.0.255 host 192.168.2.10
route-map NAT_PBR
set interface loopback 100
int x/x
description wan interface
ip nat outside
no ip redirects
ip policy-route NAT_PBR
ip nat inside source list nat-pinning interface loopback100
Kind Regards
Paul
not sure what you are asking: what IP address (local or tanslated) do the wi-fi clients need to access by domain name ?
I have attached PNG file to my first post.
I want to be able access server.domain.com from wi-fi network which IP address is 100.100.100.5
It goes like this
w-fi client-192.168.1.66 > NAT 100.100.100.5 > 100.100.100.10 NAT> 192.168.2.10-server
all this happens on the same router.
Hello
int loopback 100
description Nat_pin
ip nat inside
route-map NAT_PBR
int x/x
ip nat outside
no ip redirects
Kind Regards
Paul
Thank you very much! That is what I was looking for! :)
