Access to the external ip from the local network
Jame
Greetings colleagues
I ran into the following problem, I have two local subnet, office users are in the network 192.168.15.0/24 and also have a network DMZ 192.168.90.0/24 in which there is a web server with an IP address of 192.168.90.15.
192.168.15.0/24 >>> 5.5.5.5 (NAT Overload)
192.168.90.15 >>> 5.5.5.4 (Static NAT)
The problem is that the users from network 192.168.15.0 are trying to reach the external IP address 5.5.5.4, but they cannot connect to the web server. (At local IP address 192.168.90.15 they connect successfully)
The NVI NAT on my router (Cisco ISR 4331 IOS XE 16.6) is not supported, any idea how to get the users to connect to my web server (192.168.90.15) in DMZ at external IP address?
Attached the schematic
RUNNING CONFIG ROUTER
interface GigabitEthernet0/0/2.15
encapsulation dot1Q 15
ip address 192.168.15.1 255.255.255.0
ip nat inside
interface GigabitEthernet0/0/2.90
encapsulation dot1Q 90
ip address 192.168.90.1 255.255.255.0
ip nat inside
interface GigabitEthernet0/0/1
ip address 5.5.5.5 255.255.255.240
ip nat outside
ip route 0.0.0.0 0.0.0.0 5.5.5.1
ip nat inside source list NAT-OVERLOAD interface GigabitEthernet0/0/1 overload
ip access-list extended NAT-OVERLOAD
10 permit ip 192.168.15.0 0.0.0.255 any
ip nat name ~~~WEB-SERVER~~~ inside source static 192.168.90.15  5.5.5.4
2 Accepted Solutions
Hello
You can hairpin to that DMZ public address.
Review attached file.
Kind Regards
Paul
Sorry, your solution really works! I am not much confused, with interface 0/2.90, you specified
no ip outside
although it should be inside.
I am attaching a working configuration, maybe someone will need it
ROUTER CONFIG
interface Loopback0
description --- NAT-HAIRPING
ip address 169.254.255.254 255.255.255.255
ip nat inside
interface GigabitEthernet0/1
--- WAN
ip nat outside
interface GigabitEthernet0/2
no sh
interface GigabitEthernet0/2.15
description --- USERS
ip nat outside
ip policy route-map PBR
interface GigabitEthernet0/2.90
description --- DMZ
ip nat inside
ip nat inside source list NAT-HAIRPING interface GigabitEthernet0/1 overload
ip nat inside source list NAT-OVERLOAD interface GigabitEthernet0/1 overload
ip nat inside source static 192.168.90.15 5.5.5.4 extendable
ip access-list extended NAT-HAIRPING
permit ip 192.168.15.0 0.0.0.255 host 192.168.90.15
permit ip 192.168.90.0 0.0.0.255 host 192.168.90.15
deny ip 192.168.15.0 0.0.0.255 192.168.15.0 0.0.0.255
deny ip 192.168.90.0 0.0.0.255 192.168.90.0 0.0.0.255
permit ip 192.168.90.0 0.0.0.255 any
route-map PBR permit 10
set interface Loopback0
11 Replies 11
I will do small lab and update you
Thanks, man! I look forward to hearing from you.
JeraldAlfonso
I've been working with networks for 15 years, you can trust me. It's impossible to do that.
Hello
Kind Regards
Paul
Yes, it worked, but now users on network 192.168.15.0 cannot access the Internet
Hello
Can you post the configuration as it is currrently please
Kind Regards
Paul
no ip outside
ROUTER CONFIG
interface Loopback0
ip nat inside
--- WAN
ip nat outside
no sh
ip nat outside
description --- DMZ
ip nat inside
I found an even simpler solution, by removing PBR and Loopback in my case it turned out to be possible to bypass the simple deny of networks in the ACL "NAT-OVERLOAD"
NEW SOLUTION
ip nat outside
description --- DMZ
ip nat inside
for non-NVI NAT capable routers, the config below should work (added configuration parts are marked in bold
interface Loopback0
ip address 1.1.1.1 255.255.255.252
ip nat outside
ip policy route-map LOOP_OUT_RM
interface Loopback1
ip address 2.2.2.2 255.255.255.255
ip nat outside
ip nat inside
ip nat inside
ip policy route-map IN_OUT_RM
ip policy route-map OUT_IN_RM
ip nat pool LAN_HOSTS_NAT_POOL 5.5.5.4 5.5.5.4 prefix-length 28
ip nat inside source list LAN_HOSTS_ACL pool LAN_HOSTS_NAT_POOL overload
ip access-list extended LAN_HOSTS_ACL
permit ip host 192.168.90.15 any
ip access-list extended LAN_HOSTS_NAT_SRC
permit ip host 5.5.5.4 any
ip access-list extended LAN__HOSTS_NAT_DST
permit ip any host 5.5.5.4
route-map LOOP_OUT_RM permit 10
match ip address LAN_HOSTS_NAT_SRC
set interface GigabitEthernet0/0/1
route-map IN_OUT_RM permit 10
match ip address LAN_HOSTS_ACL
route-map OUT_IN_RM permit 10
match ip address LAN_HOSTS_NAT_DST
set interface Loopback1
This solution does not work
Attached the configuration.
you did not configure it the way I suggested. Make the change marked in bold:
--> no ip nat outside
no ip virtual-reassembly in
duplex auto
speed auto
media-type rj45
--> no ip nat inside source list NAT-OVERLOAD interface GigabitEthernet0/1 overload
