Acl query on cisco ASR 1006 router
Raja_D
Hi..
The below configuration of ACL belongs to the two cisco ASR1006 router's, where for the Router 1 I am able to view the acl sequence number as 240 which out digging much into the acl 16 to identify the sequence number but where as the same kind of router which is Router 2 does not display the sequence number unless I have dig to the acl list number to find the sequence number associating to it.
Is there any configuration that could be done on the second router which could help to get the sequence number along with the acl number for the Router 2..
Kindly advise.
Router 1:
show run | i 10.160.101.128
access-list 16 240 permit 10.160.101.128 0.0.0.63
Router 2:
show run | i 10.64.211.128
access-list 15 deny   10.64.211.128 0.0.0.63
access-list 19 deny   10.64.211.128 0.0.0.63
5 Replies 5
Mark Malone
Hi what about show access-list 15 | I 10.64.211.128 or show access-list | I 10.64.211.128 ?
Mark,
I am able to get the sequence number if i go through the show statement as given below in Router 2
show ip access-list 15 | i 10.64.211.128
6790 deny   10.64.211.128, wildcard bits 0.0.0.63
But would like to get the sequence number visibility just like how you could notice in my Router 1 output.
Hello
Are these routers using a different IOS?
res
Paul
Kind Regards
Paul
Paul,
I notice that the IOS version is same on both the router.. as given below.
Router 1: Ios version:
Cisco IOS XE Software, Version 03.13.02.S - Extended Support Release
Cisco IOS Software, ASR1000 Software (X86_64_LINUX_IOSD-ADVENTERPRISEK9-M), Version 15.4(3)S2, RELEASE SOFTWARE (fc3)
Cisco IOS-XE software, Copyright (c) 2005-2015 by cisco Systems, Inc.
All rights reserved.  Certain components of Cisco IOS-XE software are
documentation or "License Notice" file accompanying the IOS-XE software,
or the applicable URL provided on the flyer accompanying the IOS-XE
ROM: IOS-XE ROMMON
Router 2: Ios version
ROM: IOS-XE ROMMON
Muhammad Shahid
i am not sure if commands are different for this version of cisco but i tried on cisco 800 and ME3400 and only
show access-list
shows the port number with the seq number.
