acl
csc010854800
can we put ACL on 2950 switch to block some IP's of some range.
plz explain.
Giuseppe Larosa
Hello Yogesh,
the answer is no
even if you can define an ACL you cannot find a way to apply it to process user traffic because the device acts as a L2 LAn switch.
Hope to help
Giuseppe
Yogesh,
It depends!
Are you thinking about Port-ACL?
Please check this link out!
http://www.cisco.com/en/US/docs/switches/lan/catalyst2960/software/release/12.2_44_se/configuration/guide/swacl.html#wp1285529
Note: Apply an ACL only to inbound Layer 2 interfaces.
HTH,
Toshi
Leo Laohoo
Not on a 2950.
