ACLs in C9500
mk24
Hi all,
we'd like to implement ACLs in our C9500 core switches. Could you please help with two (presumably quite easy) questions:
  • Am I right that in extended ACLs on this switch there is no implicit deny at the end of every ACL? That's at least what it looks like in a short test that I did.
  • There are several distribution/access switches connected to our core switches. If I apply the ACLs to the vlan interfaces in my L3 core switch: is it necessary to have an ACE in every ACL that allows traffic within the subnet that is used in the respective vlan so end devices within this vlan can communicate to each other? I've seen it in some configs that others have done but I was never sure if it's really needed ... e.g.
    permit ip 192.168.100.0 0.0.0.255 192.168.100.0 0.0.0.255
Thanks, BR,
mk24
Giuseppe Larosa
Hello @mk24 ,
just a question are you going to apply ACLs to the SVI interfaces or you mean VLAN ACL VACLs ?
in first case  (SVI) 2) is not needed as intra VLAN traffic does not hit the SVI
  and 1) an implicit deny ip any any there should be at the end of the ACL
if you mean VACL 2) intra VLAN traffic needs to be permitited
Hope to help
Giuseppe
Giuseppe Larosa
Hello @mk24 ,
Hope to help
Giuseppe
Hi Giuseppe,
we are planning to apply the ACLs to the SVIs. So we won't need the permit for inter-vlan traffic and have to add an explicit deny at the end of every ACL.
Thanks for your help!
BR,
mk24
