Add /32 route ro null0 RTBH by community
Hi router send netflow for the server if server detect attack on my network announce /32 ip address victim ip
by community 65000:400
Now How edit route-map if announe ip address by this ip address by this community send to null 0 and if announce stop back to normal route ???
Hello
If you wish to inform bgp peers to initiate RTBH for a particular server that’s being attacked then depending on how the server is initially being advertised)?
Example:
rtr 1
int x.x
descritipn lan
ip address 10.10.10.1 255.255.255.0
or
ip route 10.10.10.10 255.255.255.255 x.x.x.x tag 99 name Server
ip access-list standard server
permit host 10.10.10.10
route-map ServerCom
match ip address server
set community 65000:400
router bgp xxxx
neighbour <rtr2> send community both
network 10.10.10.10 mask 255.255.255.255 route-map ServerComm out
or
neighbour <rtr2> route-map ServerComm out
redistribute static
Apply RTBH on upstream bgp rtr2
rtr2
ip route 169.254.254.254 255.255.255.255 null0
int null0
no ip unreachables
ip community-list 5 permit 65000:400
route-map RTBH
match community 5
set ip next-hop 169.254.254.254
set community no-export
route-map RTBH permit 100
router bgp xxxx
neighbour <rtr1> route-map RTBH in
Kind Regards
Paul
Hello
Example:
rtr 1
int x.x
descritipn lan
or
route-map ServerCom
router bgp xxxx
or
redistribute static
rtr2
int null0
no ip unreachables
route-map RTBH
match community 5
router bgp xxxx
Kind Regards
Paul
rtr2
int null0
no ip unreachables
route-map RTBH
match community 5
this part is solution
