Add guest mbssid 'tmp' to a working 1941w config
malarivi
I am trying to add an isolated guest network to my router/ap. I was able to trunk vlan 1 at the AP but I am unable to get a dhcp address or ping the router with a manual address from SSID 'tmp' on vlan100
Router
LAR#sh run
Building configuration...
Current configuration : 5519 bytes
! Last configuration change at 20:48:47 UTC Sat Oct 17 2015 by mlar
version 15.3
hostname LAR
boot-start-marker
boot-end-marker
logging buffered 51200 warnings
no aaa new-model
service-module wlan-ap 0 bootimage autonomous
ip dhcp excluded-address 10.0.0.1
ip dhcp excluded-address 10.0.0.1 10.0.0.64
ip dhcp excluded-address 192.168.1.1
ip dhcp excluded-address 192.168.1.1 192.168.1.64
ip dhcp pool LAR
 import all
 network 10.0.0.0 255.255.255.0
 default-router 10.0.0.1
 dns-server 10.0.0.2
ip dhcp pool TMP
 import all
 network 192.168.1.0 255.255.255.0
 default-router 192.168.1.1
 dns-server 192.168.1.1
no ip domain lookup
ip domain name lariv
ip host itxfiler 10.0.0.2
ip name-server 10.0.0.2
ip cef
ipv6 spd queue min-threshold 62
ipv6 spd queue max-threshold 63
no ipv6 cef
crypto pki...
license accept end user agreement
license boot module c1900 technology-package securityk9
license boot module c1900 technology-package datak9
hw-module ism 0
username mlar privilege 15 secret 5 ...
redundancy
interface Embedded-Service-Engine0/0
 no ip address
 shutdown
interface GigabitEthernet0/0
 description " *** LAN ACCESS PORT *** "
 no ip address
 shutdown
 duplex auto
 speed auto
interface wlan-ap0
 description " *** AP MGMT *** "
 ip unnumbered Vlan1
 arp timeout 0
 no mop enabled
 no mop sysid
interface GigabitEthernet0/1
 description " *** WAN DHCP ***
 ip ddns update hostname lariv.servebeer.com
 ip ddns update no-ip
 ip address dhcp hostname lar
 ip nat outside
 ip virtual-reassembly in
 duplex auto
 speed auto
interface Wlan-GigabitEthernet0/0
 description " *** BUILTIN 3502 AP *** "
 switchport mode trunk
 no ip address
interface GigabitEthernet0/1/0
 no ip address
interface GigabitEthernet0/1/1
 no ip address
interface GigabitEthernet0/1/2
 no ip address
interface GigabitEthernet0/1/3
 no ip address
 power inline never
interface GigabitEthernet0/1/4
 no ip address
interface GigabitEthernet0/1/5
 no ip address
interface GigabitEthernet0/1/6
 description " *** NAS 2x GE LACP *** "
 no ip address
 shutdown
 no cdp enable
interface GigabitEthernet0/1/7
 no ip address
 no cdp enable
interface Vlan1
 ip address 10.0.0.1 255.255.255.0
 ip nat inside
interface Vlan100
 description TMP
 ip nat inside
 no autostate
ip forward-protocol nd
no ip http server
ip http access-class 1
ip http authentication local
no ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
ip nat inside source list 1 interface GigabitEthernet0/1 overload
ip nat inside source static tcp 10.0.0.2 51413 interface GigabitEthernet0/1 51413
ip nat inside source static udp 10.0.0.2 51413 interface GigabitEthernet0/1 51413
route-map INCOMING permit 10
 match ip address 199
access-list 1 permit 10.0.0.0 0.0.0.255
control-plane
line con 0
 login local
line aux 0
line 2
 no activation-character
 no exec
 transport preferred none
 transport output ssh
 stopbits 1
line 67
 no exec
 transport input ssh
line vty 0 4
 access-class 1 in
 privilege level 15
 login local
 transport input ssh
line vty 5 15
 access-class 1 in
 privilege level 15
 login local
 transport input ssh
scheduler allocate 20000 1000
end
LAR#sh vlans
No Virtual LANs configured.
LAR#sh vlan-switch
VLAN Name                             Status    Ports
1    default                          active    Gi0/1/0, Gi0/1/1, Gi0/1/2, Gi0/1/3, Gi0/1/4, Gi0/1/5, Gi0/1/6, Gi0/1/7
1002 fddi-default                     act/unsup
1003 token-ring-default               act/unsup
1004 fddinet-default                  act/unsup
1005 trnet-default                    act/unsup
VLAN Type  SAID       MTU   Parent RingNo BridgeNo Stp  BrdgMode Trans1 Trans2
1    enet  100001     1500  -      -      -        -    -        1002   1003
1002 fddi  101002     1500  -      -      -        -    -        1      1003
1003 tr    101003     1500  1005   0      -        -    srb      1      1002
1004 fdnet 101004     1500  -      -      1        ibm  -        0      0
1005 trnet 101005     1500  -      -      1        ibm  -        0      0
local.ap#sh run
Current configuration : 3584 bytes
version 12.4
no service pad
service password-encryption
hostname local.ap
logging rate-limit console 9
enable secret 5 $1$8CzD$PqkVaQHWA.tZ6F078QUgs/
enable password 7 073C71405D5A09
no aaa new-model
no ip source-route
dot11 syslog
dot11 ssid lar
   vlan 1
   authentication open
   authentication key-management wpa version 2
   mbssid guest-mode
   wpa-psk ascii 7 03075A0D031D204F4B1B
dot11 ssid tmp
   vlan 100
   authentication open
   mbssid guest-mode
   wpa-psk ascii 7 111D1C16031C0E18557878
username mlar privilege 15 password 7 ...
bridge irb
interface Dot11Radio0
 no ip address
 no ip route-cache
 encryption mode ciphers aes-ccm tkip
 encryption vlan 100 mode ciphers aes-ccm tkip
 encryption vlan 1 mode ciphers aes-ccm tkip
 ssid lar
 ssid tmp
 antenna gain 0
 mbssid
 speed  basic-1.0 basic-2.0 basic-5.5 basic-11.0 basic-6.0 basic-9.0 basic-12.0 basic-18.0 basic-24.0 basic-36.0 basic-48.0 basic-54.0 m0. m1. m2. m3. m4. m5. m6. m7. m8. m9. m10. m11. m12. m13. m14. m15.
 station-role root
 beacon period 1000
interface Dot11Radio0.1
 encapsulation dot1Q 1 native
 no ip route-cache
 bridge-group 1
 bridge-group 1 block-unknown-source
 no bridge-group 1 source-learning
 no bridge-group 1 unicast-flooding
interface Dot11Radio0.100
 encapsulation dot1Q 100
 no ip route-cache
 bridge-group 100
 bridge-group 100 block-unknown-source
 no bridge-group 100 source-learning
 no bridge-group 100 unicast-flooding
 bridge-group 100 spanning-disabled
interface Dot11Radio1
 no ip address
 no ip route-cache
 ssid lar
 antenna gain 0
 dfs band 3 block
 speed  basic-6.0 basic-9.0 basic-12.0 basic-18.0 basic-24.0 basic-36.0 basic-48.0 basic-54.0 m0. m1. m2. m3. m4. m5. m6. m7. m8. m9. m10. m11. m12. m13. m14. m15.
 channel dfs
 station-role root
 beacon period 1000
interface Dot11Radio1.1
 no ip route-cache
 bridge-group 1
 bridge-group 1 subscriber-loop-control
 bridge-group 1 spanning-disabled
interface Dot11Radio1.100
 no ip route-cache
 bridge-group 100
 bridge-group 100 subscriber-loop-control
 description the embedded AP GigabitEthernet 0 is an internal interface connecting AP with the host router
 no ip address
 no ip route-cache
 no keepalive
 bridge-group 1
interface GigabitEthernet0.100
 no ip route-cache
 no keepalive
 bridge-group 100
interface BVI1
 ip address 10.0.0.3 255.255.255.0
 no ip route-cache
ip default-gateway 10.0.0.1
no ip http server
bridge 1 protocol ieee
bridge 1 route ip
bridge 100 protocol ieee
line con 0
 privilege level 15
 login local
line vty 0 4
 login local
 transport input all
cns dhcp
end
I do not see vlan 100 on LAR. Did you create it?
Create BVI100 on Local.ap and ping 192.168.1.1 to make sure your trunk works properly. Then delete it.
interface BVI100
 ip address 192.198.1.3 255.255.255.0
 no ip route-cache
If I understood correctly, your wireless users connect to local.ap and then go on LAR to access internet. It would be more clear if you share your topology.
Masoud
LAR is management and internet traffic for the server/IT network.
TMP is the isolated guest network that should only be able to reach 10.0.0.2 port 53
BVI100 fails to respond to ping
malarivi
LAR is my management network (vlan1) which is used only by me to get to the internet
There is a caching dns server sitting on this network the router uses.
I get dhcp lease for 10.0.0.0/24
Can access everything
the TMP ssid (vlan100) is supposed to have isolated access only to the internet
Manual ip of 192.168.1.65/24 does not respond to ping.
AP responds to ping, but traceroute shows its going through 10.0.0.1 (10.0.0.3 BVI1?)
It was to my understanding that I do not want a BVI on that network for better security?
