ADSL https problem with 827-4v
hi
i have an adsl line,connected to 827 series router.Users are browsing without any problem,continues internet connection is available.but some of the websites are available, like if you go to http://www.icici.com and if you try to login(it's an https link)it's not going
there is no access list configured to block https port 443.
this is my configuration.
sh run
Building configuration...
Current configuration : 1225 bytes
version 12.2
no service pad
hostname Router
logging queue-limit 100
ip subnet-zero
vpdn enable
vpdn-group pppoe
request-dialin
protocol pppoe
--More-- !
no voice hpi capture buffer
no voice hpi capture destination
interface Ethernet0
ip address 192.5.x.x.255.255.0
ip nat inside
hold-queue 100 out
interface ATM0
no ip address
ip mtu 1452
no atm ilmi-keepalive
--More-- dsl operating-mode auto
hold-queue 224 in
interface ATM0.1 point-to-point
ip mtu 1452
pvc 1/33
pppoe-client dial-pool-number 1
interface Dialer1
ip address negotiated
ip mtu 1452
ip nat outside
encapsulation ppp
dialer pool 1
ppp authentication chap callin
ppp chap hostname rmsllc
ppp chap password 0 rms54321
ppp pap sent-username xxx password xxx
ip nat inside source list 1 interface Dialer1 overload
ip classless
ip route 0.0.0.0 0.0.0.0 Dialer1
--More-- no ip http server
access-list 1 permit 192.x.x.0 0.0.0.255
call rsvp-sync
voice-port 1
voice-port 2
voice-port 3
voice-port 4
line con 0
stopbits 1
line vty 0 4
login
scheduler max-task-time 5000
end
i will appreciate any inputs.
Thanks & Regds
Binoy.
6 Replies 6
mehrdad
Level 3
Level 3
Hi Binoy,
The maximum segment size should be 1452 not mtu.
6 bytes for PPPoE header and 2 bytes for PPP protocol ID so check MSS 1452 or MTU 1492.
you can define MSS through "ip adjust-mss 1452" command (The ip adjust-mss command in Cisco IOSRelease 12.2(2)XH has changed to ip tcp adjust-mss )
Mehrdad
This is the reason behind this? r u sure.
can you please post the correct IOS name, so that i can purchase a copy.
rt now i have the basic IOS,so if i go for this IOS will this solve my issue.
Regds
Binoy
I don't mean that you should upgrade your IOS
I mean use "ip adjust-mss 1452" at your interface or change your MTU size 1492
Mehrdad
Hello.
I'm having a problem very similar, with a 2801 with ADSL. I can't access HTTPS, VNC and SAP, through Tunnel, EZVPN or direct access. I made the configuration suggested with no success. I have attached the current 2801 configuration. I have tested the "ip tcp adjust-mss" in Dialer Interface too with the same result.
Does anybody help me?
pls check this out "ip tcp adjust-mss 1400" on the interface FastEthernet0/0 and let me know pls.
Hi ...
It worked fine. All services are OK now. Thank you for your support.
Best regards ...
