adsl problems
fcatalao
i have put up various posts regarding this problem and no one help been able to help.
but on my own i have progressed and i amk almost there but just cannot get this problem solved.
i have the folowing
2811 w/ wic-1adsl and
Cisco IOS Software, 2800 Software (C2800NM-ADVIPSERVICESK9-M), Version 12.3(14)T, RELEASE SOFTWARE (fc1)
intially i tried using the pppoe & dialer but did not even negotiate ppp.now i am using pppoa & virtual-template.
i am now able to negociate ppp up to and including lcp with success. i cannot get ipcp to work. i´ve tried various ppp ipcp commands but to no avail.
my router configuration
interface FastEthernet0/0
description LAN DefaultGateway
ip address 10.10.10.250 255.255.255.0
ip nat inside
ip virtual-reassembly
ip tcp adjust-mss 1452
duplex auto
speed auto
no cdp enable
interface FastEthernet0/1
no ip address
shutdown
duplex auto
speed auto
interface ATM0/0/0
no ip address
no atm ilmi-keepalive
dsl operating-mode auto
interface ATM0/0/0.1 point-to-point
pvc 0/35
encapsulation aal5snap
protocol ppp Virtual-Template1
interface ATM0/1/0
no ip address
shutdown
interface Virtual-Template1
ip address negotiated previous
ip mtu 1492
ip nat outside
load-interval 30
ppp pap sent-username xxx password xxx
ppp ipcp route default
ppp timeout authentication 30
ip classless
ip http server
no ip http secure-server
ip nat inside source list 1 interface Virtual-Template1 overload
access-list 1 permit 10.10.10.0 0.0.0.255
ppp negotiation output
May 4 10:35:16.987: ppp10 LCP: MagicNumber 0x12F0D8AC (0x050612F0D8AC)
*May 4 10:35:16.999: ppp10 LCP: I CONFACK [ACKsent] id 2 len 10
*May 4 10:35:16.999: ppp10 LCP: MagicNumber 0x12F0D8AC (0x050612F0D8AC)
*May 4 10:35:16.999: ppp10 LCP: State is Open
*May 4 10:35:16.999: ppp10 PPP: Phase is AUTHENTICATING, by the peer
*May 4 10:35:16.999: ppp10 PAP: Using hostname from interface PAP
*May 4 10:35:16.999: ppp10 PAP: Using password from interface PAP
*May 4 10:35:16.999: ppp10 PAP: O AUTH-REQ id 1 len 31 from "op180442@L1.telepac"
*May 4 10:35:17.171: ppp10 PAP: I AUTH-ACK id 1 len 5
*May 4 10:35:17.171: ppp10 PPP: Phase is FORWARDING, Attempting Forward
*May 4 10:35:17.179: Vi1.1 PPP: Phase is ESTABLISHING, Finish LCP
*May 4 10:35:17.179: Vi1.1 PPP: Phase is UP
*May 4 10:35:17.179: Vi1.1 IPCP: O CONFREQ [Closed] id 1 len 10
*May 4 10:35:17.179: Vi1.1 IPCP: Address 0.0.0.0 (0x030600000000)
*May 4 10:35:17.179: Vi1.1 PPP: Process pending ncp packets
*May 4 10:35:17.191: Vi1.1 IPCP: I CONFNAK [REQsent] id 1 len 0
*May 4 10:35:17.191: Vi1.1 IPCP: Received illegal length, len 0, discarding packet
*May 4 10:35:17.335: Vi1.1 IPCP: I CONFREQ [REQsent] id 233 len 0
*May 4 10:35:17.335: Vi1.1 IPCP: Received illegal length, len 0, discarding packet
*May 4 10:35:19.163: Vi1.1 IPCP: TIMEout: State REQsent
*May 4 10:35:19.163: Vi1.1 IPCP: O CONFREQ [REQsent] id 2 len 10
*May 4 10:35:19.163: Vi1.1 IPCP: Address 0.0.0.0 (0x030600000000)
*May 4 10:35:19.175: Vi1.1 IPCP: I CONFNAK [REQsent] id 2 len 0
*May 4 10:35:19.175: Vi1.1 IPCP: Received illegal length, len 0, discarding packet
*May 4 10:35:20.359: Vi1.1 IPCP: I CONFREQ [REQsent] id 234 len 0
*May 4 10:35:20.359: Vi1.1 IPCP: Received illegal length, len 0, discarding packet
*May 4 10:35:21.179: Vi1.1 IPCP: TIMEout: State REQsent
*May 4 10:35:21.179: Vi1.1 IPCP: O CONFREQ [REQsent] id 3 len 10
*May 4 10:35:21.179: Vi1.1 IPCP: Address 0.0.0.0 (0x030600000000)
*May 4 10:35:21.191: Vi1.1 IPCP: I CONFNAK [REQsent] id 3 len 0
*May 4 10:35:21.191: Vi1.1 IPCP: Received illegal length, len 0, discarding packet
*May 4 10:35:23.195: Vi1.1 IPCP: TIMEout: State REQsent
thisisshanky
Level 11
Level 11
You should ask your service provider, if you should be using pppoe or pppoa.
I have a similar setup with dialer interfaces, and it works perfect with dialer interfaces and PPPOE. Provider is SBC>
Sankar Nair
UC Solutions Architect
Pacific Northwest | CDW
CCIE Collaboration #17135 Emeritus
study_voip
hi,
Don't use PPPoA, it did not work, use PPPoE only
create dialer interface,
interface Dialer1
ip mtu 1452
encapsulation ppp
no ip route-cache cef
dialer pool 1
ppp pap sent-username xxxx password xxx
then remember,
add this one under your atm 0/0/0.1 point-to-point
pppoe-client dial-pool-number 1
good luck
