ADSL2+/PPPoE on Cisco 1801?
frank.mcdaid
Hi guys,
I am in the process of setting up a cisco 1801 router for an ADSL 2+ connection. As this isn't something i've done before, i have a few questions:
1. My internet connection is uses PPPoE. The 1801 Data sheet says the router supports PPPoA. Can I use this router for my internet connect? A guy I work with says it shouldn't matter, and i've spent a fair bit of time searching cisco.com, but i haven't found a Definitive answer. Can someone point my in the right direction?
2. As stated above, my connection is ADSL 2+. My 1801 is running 12.4(15)T4 Advanced IP services IOS. Are these copmatible with each other?
apach
You can use c180x-advipservicesk9-mz.124-15.T3.bin as PPPoE client.
