Advice on network design.
jfinley
I have a design question which I'd like some advice on. I have a router sitting at a hospital. This router has to connect to two different office suites via fiber. Both suites connect in the same closet and the fiber to the router is a few blocks away. Do I purchase a switch with layer 3 capabilities or should I do a "router-on-a-stick" and vlan them? I'm not sure of the bandwidth needed so I am swaying toward the L3 switch to subnet the two suites. Any advice and suggested parts would be helpful! Thanks.
Joe
scottmac
Level 10
Level 10
Is this "dark fiber" (i.e., not to a carrier, just glass between the hospital and the offices)?
What routers are in-place already?
What kind of traffic are you expecting? (VoIP, X-Ray, productivity ... all of the above)?
What kind of security is required? Have you compared the overall setup with the HIPAA requirements?
This would be helpful information ....
Scott
1 - Dark fiber.
2 - Cisco 3725 w/ a DS3 module going to Corp.
3 - All the above
3 - HIPAA, yes.
