04-09-2018 10:34 PM - edited 03-05-2019 10:15 AM
I have installed a CSR1000V on a Linux virtalization and given 4 CPUs, 10 GB of RAM, then activated the license as per the procedure. but in the license details command output is is showing as active & not in use. Please suggest me on the same.
show platform hardware throughput level
The current throughput level is 1000 kb/s
show license detail
Index: 1 Feature: sec_1G Version: 1.0
License Type: Permanent
Start Date: N/A, End Date: Jan 08 2021
License State: Active, Not in Use
License Count: Non-Counted
License Priority: Medium
Store Index: 0
Store Name: Primary License Storage
Solved! Go to Solution.
04-10-2018
12:03 AM
- last edited on
05-15-2023
09:40 PM
by
Translator
04-10-2018
12:03 AM
- last edited on
05-15-2023
09:40 PM
by
Translator
have you set the
license boot level
followed by a reload ?
04-10-2018 12:07 AM
04-10-2018
12:20 AM
- last edited on
05-15-2023
09:41 PM
by
Translator
just to be sure, did you use the
license boot level
command in global config mode ?
CSR100V(config)#license boot level
