Aggregating WIC-1 on 2821 router
tasete
Greetings-
I currently have a 2821 running v12.4(3i) with an internal WIC-1DSU-T1-V2 module. I am increasing my internet speed from a single T1 to a 2xT1, which entails 2 RJ-45 cable handoffs from my Verizon demark. To accommodate, do I only need to purchase an additional WIC-1DSU-T1-V2 module and insert into chassis? Are there config examples available for aggregating 2 T1 links? Or is there some other hardware / software requirements? Can the 2800 series handle 2 WIC-1s?
Scott
2 Accepted Solutions
rtjensen4
Level 4
Level 4
Hi Scott,
YEs, the 2821 can handle multiple T1s. If you want ot aggregate the two T1s into a single 3mbps circuit, you'll want to use PPP multilink
Here's an example of how you'd configure that:
Interface s0/1/0
encapsulation ppp
ppp multilink
ppp multilink group 1
interface s0/2/0
encapsulation ppp
ppp multilink
interface Multilink1
ip address x.x.x.x x.x.x.x
ip access-group 101 in
ppp multilink
etc
etc
The general idea is that the multilink interface acts as the aggregator, where you apply your IP, ACL etc etc. The individual T1s don't have much config on them.
Collin Clark
Scott-
A 2821 has no problems handling 2 T1's. You can add the second card or buy a 2 port card, either will work just fine. Here's a link on configuring them in a multilink bundle-
https://packetpros.com/cisco_kb/VWIC-MFT_MultiLinkPPP.html
Hope it helps.
rtjensen4
Level 4
Level 4
Hi Scott,
Interface s0/1/0
encapsulation ppp
ppp multilink
interface s0/2/0
encapsulation ppp
ppp multilink
ppp multilink
etc
etc
Perfect!
Thanks all for the quick help. I'll get a bigger pipe yet!
S.
Collin Clark
Scott-
Hope it helps.
