AIM-ATM and 3845 : minimun feature set required
rrsstefano
I noted that releases 12.4 and 12.3T with ipbase feature set are note able to recognize AIM-ATM on a 3845 chassis while advanced ip services is able to.
The Software Advisor tool tell me that ipbase should be OK.
The CCO documentation regarding AIM-ATM compatibility is almost limited to 26XX-36XX-37XX platform
Any suggestion?
pkhatri
Level 11
Level 11
According to Feature Navigator, it appears that you need at least the IP Voice feature set for this. It seems to be supported on any feature set above IP Base, in fact.
Hope that helps - pls do remember to rate posts that help.
Paresh
....then the indication from software advisor is not correct...
or there are some bugs?
thanks
It's not uncommon for Software Advisor and Feature Navigator to be somewhat out of sync.
Since you have already tried the IP Base image and found that it did not recognise the card, I would say Feature Navigator is correct here...
Paresh
