Allow only specific URLs on 861 router using MQC
I configured a Cisco 861 router to allow only youtube.com and block all other URLs.
I used the below configuration but is not working. Actually everything is blocked even the access to the router.
Is there any other way to acheive this requirement?
class-map match-any YOUTUBE
match protocol http host *youtube.com*
class-map match-all YOUTUBE-ONLY
match not class-map YOUTUBE
policy-map WEB-ACCESS
class YOUTUBE-ONLY
  drop
interface Vlan1
service-policy input WEB-ACCESS
blau grana
Level 7
Level 7
Hi Michalis
Try to modify policy-map WEB-ACCESS ->
class YOUTUBE-ONLY
  drop
class class-default
Best Regards
Please rate helpful posts
Best Regards Please rate all helpful posts and close solved questions
Thanks Blau for your response.
I solved the problem by adding "match protocol http" to match only http protocol and not all traffic.
  match protocol http
