Am I using Stateful or Stateless method for my dhcp router?
Mirul
Hello all.
Some of my friends telling me that I am using stateless method for my Dhcp router and some of them telling me that I am using stateful method.
I attached the packet tracer for references.
This is the current configuration:
Mark Elsen
 - Depends what you mean by those terms, if you for instance incorporate that the DHCP service has to keep record of allocated addresses , then according to my opinion it becomes stateful.
 M.
-- Let everything happen to you
       Beauty and terror
      Just keep going
       No feeling is final
Reiner Maria Rilke (1899)
luis_cordova
Hi @Mirul ,
In your case you are using statefull, because when using DHCP, the router keeps a record of the addresses provided by DHCP.
When a PC obtains addressing by itself based on the parameters of the router, then the router does not keep any record (stateless).
https://networkengineering.stackexchange.com/questions/21162/stateful-vs-stateless-ipv6
Hey,
This shows up when I type in router#show ipv6 int *any interface*
Host using stateless autoconfig for addresses.
I'm really confused right now.
Hi @Mirul ,
I have reviewed and effectively, the DHCP that can be configured in PT is a stateless.
The stateful DHCP cannot be configured in PT, it seems.
I leave you this stateful DHCP guide, but in PT not all commands are accepted:
https://www.cisco.com/en/US/docs/switches/lan/catalyst3850/software/release/3se/consolidated_guide/b_consolidated_3850_3se_cg_chapter_0101011.html#task_79FC20F74C5A469880E0C9CA380E5690
