Any wan can help to configure Cisco 7204
alincawad12
Hi every body Im facing problem with my new cisco router 7204 configuration and booting from the correct source Im sending here all when its tured on
can eny body help me
hostname(boot)#reload
Proceed with reload? [confirm]y
*Jun 7 01:46:03.543: %SYS-5-RELOAD: Reload requested by console. Reload Reason: Reload Command.
System Bootstrap, Version 12.4(12.2r)T, RELEASE SOFTWARE (fc1)
Copyright (c) 2006 by cisco Systems, Inc.
Socket jumper: not present Failsafe jumper: present = normal
FPGA revision 0x00000026
C7200 platform with 1046528 Kbytes of main memory
Readonly ROMMON initialized
Self decompressing the image : ################################################################################################################################# [OK]
%SYS-6-READ_BOOTFILE_FAIL: tftp://255.255.255.255/bootflash File read failed -- Timed out.
%Error opening tftp://255.255.255.255/bootflash (Timed out)
%SYS-6-BOOT_MESSAGES: Messages above this line are from the boot loader.
Error : compressed image checksum is incorrect 0x4C16833F
       Expected a checksum of 0xC6703725
*** System received a Software forced crash ***
signal= 0x17, code= 0x5, context= 0x0
string is disk2:y
string is disk2:y
boot: cannot find an executable image for this platform on device "slot0:"
boot: cannot find an executable image for this platform on device "slot1:"
             Restricted Rights Legend
Use, duplication, or disclosure by the Government is
subject to restrictions as set forth in subparagraph
(c) of the Commercial Computer Software - Restricted
Rights clause at FAR sec. 52.227-19 and subparagraph
(c) (1) (ii) of the Rights in Technical Data and Computer
Software clause at DFARS sec. 252.227-7013.
           cisco Systems, Inc.
           170 West Tasman Drive
           San Jose, California 95134-1706
Cisco IOS Software, 7200 Software (C7200P-KBOOT-M), Version 12.4(4)XD5, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2006 by Cisco Systems, Inc.
Compiled Tue 19-Dec-06 16:07 by alnguyen
Image text-base: 0x0000A368, data-base: 0x00C74000
Cisco 7204VXR (NPE-G2) processor (revision A) with 917504K/65536K bytes of memory.
Processor board ID 37074038
MPC7448 CPU at 1666Mhz, Implementation 0, Rev 2.2
4 slot VXR midplane, Version 2.11
Last reset from power-on
PCI bus mb1 (Slots 1, 3 and 5) has a capacity of 600 bandwidth points.
Current configuration on bus mb1 has a total of 0 bandwidth points.
This configuration is within the PCI bus capacity and is supported.
PCI bus mb2 (Slots 2, 4 and 6) has a capacity of 600 bandwidth points.
Current configuration on bus mb2 has a total of 0 bandwidth points.
Please refer to the following document "Cisco 7200 Series Port Adaptor
Hardware Configuration Guidelines" on Cisco.com <http://www.cisco.com>
for c7200 bandwidth points oversubscription and usage guidelines.
1 FastEthernet interface
3 Gigabit Ethernet interfaces
2045K bytes of NVRAM.
253008K bytes of ATA PCMCIA card at slot 2 (Sector size 512 bytes).
65536K bytes of Flash internal SIMM (Sector size 512K).
Press RETURN to get started!
*Jun 7 01:50:46.811: %LINK-3-UPDOWN: Interface GigabitEthernet0/1, changed state to down
*Jun 7 01:50:47.083: %LINK-3-UPDOWN: Interface GigabitEthernet0/2, changed state to down
*Jun 7 01:50:47.083: %LINK-3-UPDOWN: Interface GigabitEthernet0/3, changed state to down
*Jun 7 01:50:47.099: %LINK-3-UPDOWN: Interface FastEthernet0/2, changed state to down
*Jun 7 01:50:47.811: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0/1, changed state to down
*Jun 7 01:50:48.083: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0/2, changed state to down
*Jun 7 01:50:48.083: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0/3, changed state to down
*Jun 7 01:50:48.099: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEthernet0/2, changed state to down
*Jun 7 01:50:48.423: %SYS-5-CONFIG_I: Configured from memory by console
*Jun 7 01:50:48.607: %SYS-5-RESTART: System restarted --
*Jun 7 01:50:49.387: %SYS-6-BOOTTIME: Time taken to reboot after reload = 287 seconds
*Jun 7 01:50:50.279: %LINK-5-CHANGED: Interface FastEthernet0/2, changed state to administratively down
*Jun 7 01:50:50.387: %LINK-5-CHANGED: Interface GigabitEthernet0/3, changed state to administratively down
*Jun 7 01:50:56.811: %LINK-3-UPDOWN: Interface GigabitEthernet0/1, changed state to up
*Jun 7 01:50:56.903: %LINK-3-UPDOWN: Interface GigabitEthernet0/2, changed state to up
*Jun 7 01:50:57.811: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0/1, changed state to up
*Jun 7 01:50:57.903: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0/2, changed state to u
Tirumala Earla
Hi Ismail,
It looks like either your iOS is not found or corrupted. Try to troubleshoot from your RMON prompt. Below link may help you to troubleshoot your device from RMON.
http://www.cisco.com/en/US/products/hw/routers/ps359/products_tech_note09186a00800a750e.shtml
Hi Ismail,
It Seems that the IOS you have loaded on the router is corrupt. On the Cisco 7200 series, when an IOS is not found or corrupted, it has a built in IOS which contains less features but is useful to allow you to run basic configs. It is normally denoted by somethings that looks like this
Router(BOOT)#
If this is what your prompt looks like then, your IOS indeed failed to load. Do insert a new IOS to your Router.
Rustom Billimoria
