Applying ACL to external interface blocks access to internet
davorin
I have a problem on cisco C892. At the moment I apply a ACL-IN ACL on external Dialer0 int, I lose the connectivity from LAN to internet (ping, dns, http, everything), which is unwanted. While I still have RDP access from internet 2.2.2.0 network to internal server at 192.168.1.37.
From LAN to INET I want to block just SMTP, except from mail server.
From external network 2.2.2.0/24 I want to allow access to everything specified in NAT rules.
From other internet addresses I want to allow only what is specified in ACL-IN access list.
1.1.1.1 is my fixed public IP address I get on Dialer0 interface with pppoe connection.
Adding "permit ip any any" at the end of ACL-IN would make this ACL useless. I guess I need to permit just/also established connections started from LAN and pppoe?
(I have been said that the costumer has another 4 public IP addresses which are routed by ISP over 1.1.1.1 address, but they are not in use - if relevant).
Any suggestions would be more than welcome.
Here is a relevant part of router configuration:
ip cef
ip domain name domain.local
ip name-server 8.8.8.8
ip name-server 8.8.4.4
ip inspect log drop-pkt
ip inspect name WALL tcp
ip inspect name WALL udp
ip inspect name WALL tftp
ip inspect name WALL ftp
ip inspect name WALL realaudio
ip inspect name WALL icmp
ip inspect name WALL rtsp
ip inspect name WALL http
ip inspect name WALL https
ip inspect name WALL ssh
ip inspect name WALL sip
ip inspect name WALL h323
no ipv6 cef
interface FastEthernet8
 description ***INTERNET PPPoE***
 no ip address
 no ip redirects
 no ip unreachables
 no ip proxy-arp
 ip virtual-reassembly
 load-interval 30
 duplex auto
 speed auto
 pppoe enable group global
 pppoe-client dial-pool-number 1
 no cdp enable
interface Vlan1
 description === LAN ===
 ip address 192.168.1.5 255.255.255.0
 ip access-group BLOCK_SPAM in
 no ip redirects
 no ip unreachables
 no ip proxy-arp
 ip accounting output-packets
 ip flow ingress
 ip flow egress
 ip nat inside
 ip tcp adjust-mss 1452
 load-interval 30
interface Dialer0
 ip address negotiated
 ip access-group ACL-IN in
 ip mtu 1492
 ip nat outside
 encapsulation ppp
 dialer pool 1
 dialer-group 1
 ppp authentication chap callin
 ppp chap hostname pppoeusername
 ppp chap password 7 xxxxxx
 no cdp enable
 crypto map cmap
ip nat inside source list NAT interface Dialer0 overload
ip nat inside source static tcp 192.168.1.19 110 interface Dialer0 110
ip nat inside source static tcp 192.168.1.24 80 interface Dialer0 80
ip nat inside source static tcp 192.168.1.19 25 interface Dialer0 25
ip nat inside source static tcp 192.168.1.19 443 interface Dialer0 443
ip nat inside source static tcp 192.168.1.18 1750 1.1.1.1 1750 extendable
ip nat inside source static tcp 192.168.1.37 3389 1.1.1.1 3337 extendable
ip nat inside source static tcp 192.168.1.110 8000 1.1.1.1 8000 extendable
ip route 0.0.0.0 0.0.0.0 Dialer0
ip access-list extended ACL-IN
 permit ip 2.2.2.0 0.0.0.255 any
 permit esp any any
 permit udp any any eq isakmp
 permit udp any any eq non500-isakmp
 permit tcp any host 1.1.1.1 eq smtp
 permit tcp any host 1.1.1.1 eq pop3
 permit tcp any host 1.1.1.1 eq 443
 permit tcp any host 1.1.1.1 eq www
 permit tcp any host 1.1.1.1 eq 1750
 permit tcp any host 1.1.1.1 eq 8000
ip access-list extended BLOCK_SPAM
 permit tcp host 192.168.1.19 any eq smtp
 deny   tcp any any eq smtp
 permit ip any any
ip access-list extended NAT
 deny   ip 192.168.1.0 0.0.0.255 192.168.255.0 0.0.0.127
 permit ip 192.168.1.0 0.0.0.255 any
 deny   ip any any log
dialer-list 1 protocol ip permit
no cdp run
2 Accepted Solutions
any access list has an implicit 'deny', so if you don't sepcifically allow traffic, it will be blocked. Make the additions marked in bold:
permit esp any any
deny tcp any any eq pop3
deny tcp any any eq 443
deny tcp any any eq 1750
deny tcp any any eq 8000
permit ip any any
permit ip any any established is not a valid command. the command you are thinking about is permit tcp any any established. That is a valid technique to permit tcp traffic from outside that is response to something initiated from inside while denying tcp traffic that is initiated from outside. But it works only for tcp and not all of ip.
Rick
7 Replies 7
permit esp any any
permit ip any any
thank you for quick answer.
It wouldn't make more sense to change to:
permit esp any any
deny tcp any host 1.1.1.1 eq 3337
permit ip any any
All nat-ed ports, except 3337, should be accessed from everywhere.
And I'm not sure about using "permit ip any any". Does not this open this router completely?
Is there any difference in security if I block or not a certain port using ACL if is not used NAT rules?
And I would probably need to limit access to additional ports like ssh,...
if you don't want to allow 'ip any any' you need to know exactly what your users do on the Internet. Possible, of course, but tedious and tricky. One way to do it I guess is to block everthing, log it, and then create an access list based on the logs...
What about using "permit ip any any established" instead of "permit ip any any"?
Should this work?
Rick
Thank you for your help.
"permit ip any any" did the job and I have use a little bit changed ACL I have posted before.
And thanks for correcting a command to "permit tcp any any established". I have decided not to use it at the moment, because I'm not so familiar with the costumer needs. Maybe next time.
Thank you again to both of you!
I hope I have correctly closed the question.
Best regards,
Davorin
Davorin
I am glad that our suggestions have been helpful. Thank you for marking this question as solved. This will help other participants in the community to identify discussions which have helpful information. I believe that you have correctly closed the discussion. This community is an excellent place to ask questions and to learn about networking. I hope to see you continue to be active in the community.
Rick
