Applying QOS to subinterface and then to physical interface
Idan Grinshpon
Can be service policy applied to subinterface and then to physical interface aggregating this all subinterfaces (Eth)?
Are there any limitations about it.
smehrnia
Level 7
Level 7
Hi Idan,
there are a couple of thing stated by Cisco about these sort of applications:
If you apply a policy with the police command to both the interface and the subinterface, only the subinterface policer is active for the traffic that matches the class.
Cisco IOS logical interfaces do not inherently support a state of congestion and do not support the direct application of a service policy that applies a queueing method. Instead, you first need to apply shaping to the subinterface using either generic traffic shaping (GTS) or class-based shaping.
In other words, you must configure a hierarchical policy with the shape command at the parent level. Use the bandwidth command for CBWFQ, or the priority command for Low Latency Queueing (LLQ) at lower levels. Class-based shaping limits the output rate and (we can assume) leads to a congested state on the logical subinterface. The subinterface than applies "backpressure," and Cisco IOS begins queueing the excess packets that are held by the shaper.
Hope it Helps,
Soroush.
Hope it Helps!
Soroush.
