area 0 authentication message-digest
vasanth_k08
does this command makes that md5 authentication mandatory for the rest of the network segments in area 0 or just for the network connected to that particular router?
melletandre
It specify/enable all of area 0 to use MD5 autentication.
But you are still required to configure the authentication under the interfaces connected to Area 0 i.e.
router ospf 1
interface FastEthernet0/0
     ip ospf 1 area 0
     ip ospf message-digest-key 1 md5 cisco
Sanjay Shaw
Hi Kumar,
Area authentication command in the configuration enables authentication for all the interfaces of the particular area.
It means the network segments in Area 0.
BR//SS
the area authentication sets the default for all the local OSPF interfaces belonging to that area, but you can also disable/change authentication on a per-interface level if you want or need to:
R1#show ip ospf interface s0/0 | i auth
Message digest authentication enabled
R1#conf term
R1(config)#int s0/0
R1(config-if)#ip ospf authentication null
*Mar  1 00:03:32.411: %OSPF-5-ADJCHG: Process 1, Nbr 2.2.2.2 on Serial0/0 from LOADING to FULL, Loading Done
R1(config-if)#do show ip ospf interface s0/0 | i auth
R1(config-if)#
Best regards
Rolf
