How to upgrade 892SFP router
John Kellen
I have been spending hours of digging on the webpages of cisco to find a ios upgrade guide for my router.
For some reason I just can't seem to find the procudure to upgrade this router command line (892FSP)
Can anyone point me into the right direction/docs?
John
3 Accepted Solutions
Leo Laohoo
There are several ways to upgrade a router.  But I need to ask you one vital queston:  What is the distance from you or your office and the router?
First, get a good TFTP application.  I recommend TFTPd32/TFTPd64.
Next, go here and go immediately to Step 9.
Will this procedure keep the existing config in place?
Yes.
6 Replies 6
Leo Laohoo
Hello Leo,
Thank you for your reply.
I'd like to do it remote over ssh, but if really needed, the distance of my office and the router are 10 meters. Really nearby.
John
Hello Leo,
I have a TFTP server, been using it to update my catalyst switches.
I know it works fine for the switches tho ;-)
Just need to be sure.
J
Yes.
Worked out fine, thanks Leo
