AS-path filter question
Ciderza99
We are directly connected AS 1. We would like to allow AS 1 and directly connected AS in as well as networks originated in 2 with its directly connected AS. We peer with 1 and 1 peers with us and 2.
Will the below work?
ip as-path access-list 13 permit ^1_[0-9]*$
ip as-path access-list 13 permit ^1_2_[0-9]*$
Very interesting.
I tested it successfully on a route-server (it is not a recent version though).
Could you please test this one?
ip as-path access-list 13 permit ^(1)(_\1)*_([0-9]*)(_\1)*$
ip as-path access-list 13 permit ^(1)(_\1)*_(2)(_\1)*_([0-9]*)(_\1)*$
If it is not really supported, you will have to go with your original configuration.
Cheers.
Leonardo Gama
Yes, but there is a problem.
It will not permit as-path prepend...
I think this is a better option:
ip as-path access-list 13 permit ^(1)(_\1)+_([0-9]*)(_\1)+$
ip as-path access-list 13 permit ^(1)(_\1)+_(2)(_\1)+_([0-9]*)(_\1)+$
Cheers.
Hi Leonardo,
I have tested this in VIRL on 15.6(2)T and receive "invalid back reference when trying to create these two ones you supplied.
Very interesting.
Cheers.
Same issue.
We will go with the first configuration. I will try and test your example on version 12.
Thanks for your help and replies.
