ASA 5505 not failing back to the preferred route when the ISP comes back up
mspillers
I have an ASA with security plus and I set up a tracked route to failover if I lose connection to the ISP and it works, sort of.
I'm doing testing by just pulling the Ethernet cable. When I pull the preferred ISP cable, it fails over as expected. But when I plug the preferred ISP back in, the ASA still routes using the second ISP.
I see that it does add the preferred route back in with a metric of 1 but it doesn't use it unless a fail the secondary ISP (with a metric of 254)
I'm new to ASA and been searching around but other people don't seem to have this issue. What am I missing?
Misty
svansteensel
Misty,
I think since both lines are active at this point in time, you should build in a script to clear the NAT table, something like this:
event manager applet NAT-TRACK
event track 1 state any
action 0.1 cli command "enable"
action 0.2 wait 2
action 0.3 cli command "clear ip nat translations forced"
action 0.4 syslog msg "NAT translation cleared after track state change"
