CIsco 1841 VLAN routing
ronald.tuns
Hi everyone,
I'm having some trouble with routing traffic from one vlan to the other on a 1841.
What am I trying to do:
- route traffic from vlan1 to the internet with a specific public IP
- route traffic from vlan2 to the internet with a specific public IP
- allow traffic from vlan1 to vlan2 and vice versa
- NAT specific ports to a host on vlan1
What's not working:
- hosts from vlan1 can ping the vlan2 interface, but not the hosts on vlan2 and vice versa
Here's the config (I have disabled access-rules for simplicity):
hostname cisco1841
boot-start-marker
boot-end-marker
aaa new-model
aaa authentication login default local
aaa authentication login ciscocp_vpn_xauth_ml_1 local
aaa authorization exec default local
aaa authorization network ciscocp_vpn_group_ml_1 local
aaa session-id common
no process cpu extended history
no process cpu autoprofile hog
dot11 syslog
ip source-route
no ip routing
no ip cef
ip inspect name CCP_LOW dns
ip inspect name CCP_LOW ftp
ip inspect name CCP_LOW h323
ip inspect name CCP_LOW sip
ip inspect name CCP_LOW icmp
ip inspect name CCP_LOW netshow
ip inspect name CCP_LOW rcmd
ip inspect name CCP_LOW realaudio
ip inspect name CCP_LOW rtsp
ip inspect name CCP_LOW sqlnet
ip inspect name CCP_LOW streamworks
ip inspect name CCP_LOW tftp
ip inspect name CCP_LOW tcp
ip inspect name CCP_LOW udp
ip inspect name CCP_LOW vdolive
ip name-server 1.2.3.4
username admin privilege 15 password 0 notthepassword
redundancy
interface FastEthernet0/0
 description $FW_OUTSIDE$
 ip address 2.1.2.1 255.255.255.248 secondary
 ip address 2.1.2.2 255.255.255.248
 ip access-group 102 in
 ip inspect CCP_LOW out
 ip nat outside
 ip virtual-reassembly in
 no ip route-cache
 speed auto
 half-duplex
 no cdp enable
 no mop enabled
interface FastEthernet0/1
 no ip address
 no ip route-cache
 duplex auto
 speed auto
 no cdp enable
interface FastEthernet0/0/0
 no ip address
 no cdp enable
interface FastEthernet0/0/1
 switchport access vlan 2
 no ip address
 no cdp enable
interface FastEthernet0/0/2
 no ip address
 shutdown
 no cdp enable
interface FastEthernet0/0/3
 no ip address
 shutdown
 no cdp enable
interface Vlan1
 description $FW_INSIDE$
 ip address 192.168.175.252 255.255.255.0
 ip access-group 100 in
 ip nat inside
 no ip route-cache
interface Vlan2
 ip address 192.168.176.254 255.255.255.0
 ip access-group 101 in
 ip nat inside
ip forward-protocol nd
ip http server
ip http authentication local
no ip http secure-server
ip nat pool natvlan1  2.1.2.1 2.1.2.1 netmask 255.255.255.248
ip nat pool natvlan2 2.1.2.2 2.1.2.2 netmask 255.255.255.248
ip nat inside source list 100 pool natvlan1 overload
ip nat inside source list 101 pool natvlan2 overload
ip nat inside source static tcp 192.168.175.1 25 2.1.2.1 25 extendable
ip nat inside source static tcp 192.168.175.1 80 2.1.2.1 80 extendable
ip nat inside source static tcp 192.168.175.1 443 2.1.2.1 443 extendable
ip nat inside source static tcp 192.168.175.6 876 2.1.2.1 876 extendable
ip nat inside source static tcp 192.168.175.4 8550 2.1.2.1 8850 extendable
ip route 0.0.0.0 0.0.0.0 2.1.2.3
access-list 100 permit ip any any
access-list 101 permit ip any any
access-list 102 permit ip any any
control-plane
line con 0
 exec-timeout 0 0
line aux 0
line vty 0 4
 password notthepassword
 transport input all
scheduler allocate 20000 1000
end
Any help is greatly appreciated!
9 Replies 9
Dragan Ilic
Level 4
Level 4
Could you provide output of "sh vlan-sw"?
HTH,
Dragan
HTH,
Dragan
Hi Dragan,
This is the output:
VLAN Name                             Status    Ports
1    default                          active    Fa0/0/0, Fa0/0/2, Fa0/0/3
2    VLAN0002                         active    Fa0/0/1
1002 fddi-default                     act/unsup
1003 token-ring-default               act/unsup
1004 fddinet-default                  act/unsup
1005 trnet-default                    act/unsup
VLAN Type  SAID       MTU   Parent RingNo BridgeNo Stp  BrdgMode Trans1 Trans2
1    enet  100001     1500  -      -      -        -    -        1002   1003
2    enet  100002     1500  -      -      -        -    -        0      0
1002 fddi  101002     1500  -      -      -        -    -        1      1003
1003 tr    101003     1500  1005   0      -        -    srb      1      1002
1004 fdnet 101004     1500  -      -      1        ibm  -        0      0
1005 trnet 101005     1500  -      -      1        ibm  -        0      0
As Jon suggested - can you ping a PC from the router adequate interface?
If not then you have something on your hosts which is causing problems (FW or AV etc)...it MUST work in other words smiley
HTH,
Dragan
HTH,
Dragan
Hi Dragan,
I just answered Jon's question:
If I place a PC in VLAN1, I can ping the VLAN2 interface on the 1841. From the 1841, I can also ping the PC in VLAN1 from the VLAN2 interface.
So it seems that traffic behind the 1841 is not routed back for some reason...
Grtz,
Ronald
Jon Marshall
Ronald
Firstly check for firewalls on the PCs that could be blocking the pings ie. can you ping a PC from the router ?
If you can then -
1) remove acls 100 and 101 from the vlan interfaces. They are not doing anything anyway and they need modifying which would break communication if you left them applied
2) modify both acls ie. -
access-list 100 deny ip 192.168.175.0 0.0.0.255 192.168.176.0 0.0.0.255
access-list 100 permit ip 192.168.175.0 0.0.0.255 any
access-list 101 deny ip 192.168.176.0 0.0.0.255 192.168.175.0 0.0.0.255
access-list 101 permit ip 192.168.176.0 0.0.0.255 any
Jon
Hi John,
I have removed the access-list, but there is no change unfortunately.
I have checked gateway settings and firewall settings on the PC, but these are fine.
Grtz,
Ronald
Ronald
You removed the acls from the interfaces but did you modify them as i suggested ?
You still need them but modified.
Jon
svansteensel
Ronald,
Have you verified your NAT config (sh ip nat translation)? I see that your ACL's specify all traffic to be submissive to NAT, you should exclude traffic from VLAN 1 to VLAN 2 and vice versa from being NATed.
regards Sebastian
 Hello
1) Why do you have secondary addressing on the wan interface, the wan ISP will have a route back your allocated ip range anyway., can you use an single ip and then nat pool on 2.1.2.1/2 respectively
2) remove the cbac from the wan interface and apply it on the lan interfaces INBOUND., so it inspects the traffic destined to your lan.
3) I assume your acls statements of permitting all traffic are temporary especially for the wan interface as it is at present allowing everything back in, that shouldnt be the case, it should denying everything.
4) ip routing is disabled
So to summarise,
no access-list 100
no access-list 101
no access-list 102
access-list 100 permit ip any 192.168.175.0 0.0.0.255 log
access-list 101 permit ip any 192.168.176.0 0.0.0.255 log
access-list 102 deny ip any any
no ip nat inside source list 100 pool natvlan1 overload
no ip nat inside source list 101 pool natvlan2 overload
access-list 1 permit 192.168.175.0 0.0.0.255
access-list 2 permit 192.168.176.0 0.0.0.255
ip nat inside source list 1 pool natvlan1 overload
ip nat inside source list 2 pool natvlan2 overload
ip routing
no ip address 2.1.2.1 255.255.255.248 secondary
no ip inspect CCP_LOW out
ip address 2.1.2.6 255.255.255.248 ( if applicable)
interface Vlan1
ip inspect CCP_LOW in
interface Vlan2
res
Paul
Kind Regards
Paul
