03-24-2022 04:11 PM
I have a Cisco ASA 5515 that has been the border of an iBGP enterprise. Our internet provider installed a static route to pass our public IP space directly to us. We pass certain subnets of this public IP space into our enterprise network segments. The iBGP between these segments, routers, other firewalls all work great. They all utilize private ASNs.
We are now switching to a new provider. This provider is requiring eBGP and expects us to advertise our public IP ranges. ASA BGP
I have been able to configure BGP neighbors utilizing remote and local as options to mask the ASN assigned by the provider.
My question - how can I advertise only specific blocks (i.e. /24) to this one neighbor? I have been trying maps and filters without much success. Often, when the networks are public address ranges that exist within the enterprise, the maps expose the private ASNs and next hops even though the maps are configured to prepend or replace those details.
I do not want to redo the entire iBGP ASNs.
Is there any way to statically advertise network 1, 2, 3 to a specific BGP neighbor?
Solved! Go to Solution.
03-25-2022
09:12 AM
- last edited on
03-27-2022
07:49 PM
by
Translator
Finally found the solution.
On the neighbor command it needs to be as follows:
neighbor ISP local-as 5678 no-prepend replace-as
Everything immediately it up.
03-25-2022 06:37 AM
Made some more progress last night.
I am not able to advertise the route to the one Neighbor, but the AS prepend is not working.
Below are the current config details.
router bgp 65100 neighbor 192.168.1.1 remote-as 65200 neighbor 192.168.1.1 description Cust1 neighbor 192.168.1.1 password ****** neighbor 192.168.1.1 timers 10 30 neighbor 192.168.1.1 activate neighbor 192.168.2.1 remote-as 65300 neighbor 192.168.2.1 description Cust2 neighbor 192.168.2.1 password ****** neighbor 192.168.2.1 timers 10 30 neighbor 192.168.2.1 activate neighbor 192.168.3.1 remote-as 65400 neighbor 192.168.3.1 description Cust3 neighbor 192.168.3.1 password ****** neighbor 192.168.3.1 timers 10 30 neighbor 192.168.3.1 activate neighbor ISP remote-as 1234 neighbor ISP local-as 5678 neighbor ISP description Prov1 neighbor ISP password ****** neighbor ISP timers 10 30 neighbor ISP activate neighbor ISP next-hop-self neighbor ISP remove-private-as neighbor ISP route-map ISP_Route_Map out redistribute static route-map ISP_Route_Map no auto-summary no synchronization exit-address-family route-map ISP_Route_Map, permit, sequence 1 match ip address prefix-lists: ISP_Prefix_List set ip next-hop x.x.x.x set as-path prepend 5678 5678 5678 show bgp neighbor ISP advertised-routes Network Next Hop Metric Weight Path y.y.y.y/24 x.x.x.x 0 32768 ?
03-25-2022
09:12 AM
- last edited on
03-27-2022
07:49 PM
by
Translator
