ASA Behind Dual ISP Router
teymur azimov
Hi. My application is that:
Two different ISP connect to router. 1 ISP ip :85.132.21.71 and second one is ISP 2: 81.34.21.34
the router is connect to asa. Asa outside ip is 10.0.0.2 is connect to router gi0/1 interface(this ip address is 10.0.0.1).
my inside lan is 192.168.10.1/24 and 172.30.30.1/24 config at asa.
i want inside lan 192.168.10.0 is nat to 85.132.21.71 and 172.30.30.0 is nat to 81.34.21.34. i do not need ISP redundancy.
how i do this config?please help me.
8 Replies 8
   You can use policy based routing on the router to classify traffic sent out each ISP.  Is PBR supported on the router?
HTH,
Toshi
Thank you very much.
I do not know exatly how to configurate router and asa.
i want to config nat at asa and PBR config at router, but how i can do this configuration.
thanks
teymur azimov
Two different ISP connect to router. 1 ISP ip :85.x.x.x and second one is ISP 2: 81.x.x.x
i want inside lan 192.168.10.0 is nat to 85.x.x.x and 192.168.100.0 is nat to 81.x.x.x. I wish load balance ISP.
Please check my config and say your recommendation.
thanks
Router Configuration.
interface GigabitEthernet0/0.105
connected to ISP1
encapsulation dot1Q 105
ip address 85.x.x.106 255.x.x.x
interface GigabitEthernet0/0.233
connected to ISP2
encapsulation dot1Q 233
ip address 81.x.x.234 255.x.x.x
interface GigabitEthernet0/1
description connected to ASA
ip address 10.0.0.1 255.255.255.0
ip policy route-map EXCH
speed auto
access-list 101 permit ip 85.x.x.0 0.0.0.255 any             is this one public ip or inside ip address?
access-list 102 permit ip 81.x.x.0 0.0.0.255 any
route-map EXCH permit 10
match ip address 101
set ip next-hop verify-availability 85.x.x.105
route-map EXCH permit 20
match ip address 102
set ip next-hop verify-availability 81.x.x.234
ip route 0.0.0.0 0.0.0.0 85.x.x.105
ip route 0.0.0.0 0.0.0.0 81.x.x.234
ip route 0.0.0.0 0.0.0.0 10.0.0.2    can I write this one???
ASA Configuration.
interface Ethernet0/0
nameif outside
security-level 0
ip address 10.0.0.2 255.255.255.0
interface Ethernet0/1.10
nameif inside
security-level 100
ip address 192.168.10.0 255.255.255.0
interface Ethernet0/1.100
nameif inside2
security-level 80
ip address 192.168.100.0 255.255.255.0
global(outside) 1 85.x.x.108
global (outside) 2 81.x.x.236
nat(inside) 1 192.168.10.0 255.255.255.0
nat(inside2) 2 192.168.100.0 255.255.255.0
route outside 0.0.0.0 0.0.0.0 10.0.0.1
    The concept behind this is as follows:
1. You don't need to do NAT on ASA.  You need to do NAT on the router.
2. You need PBR to send traffic to each ISP you want.
f.e.
access-list 101 permit ip 192.168.10.0 0.0.0.255 any
access-list 102 permit ip 192.168.100.0 0.0.0.255 any
route-map Classify permit 10
march ip address 101
set ip next-hop 85.x.x.105
route-map Classify permit 20
march ip address 102
set ip next-hop 81.x.x.234
ip policy route-map Classify
3. You need to follow the document below to get rid of NAT problem.
Ref: http://www.cisco.com/en/US/tech/tk648/tk361/technologies_configuration_example09186a0080950834.shtml
Additional:
Router(conf)#no ip route 0.0.0.0 0.0.0.0 10.0.0.2
Router(conf)#ip route 192.168.10.0 255.255.255.0 10.0.0.2
Router(conf)#ip route 192.168.100.0 255.255.255.0 10.0.0.2
HTH,
Toshi
Thank you ver much.
i want to sure that is rigth configuration
connected to ISP1
ip nat outside
connected to ISP2
ip nat outside
ip nat inside                           ----can i write this one?
match interface GigabitEthernet0/0.105  --- can i add this command?
match interface  GigabitEthernet0/0.233  --- can i add also this one?
ip nat inside source route-map isp1 interface GigabitEthernet0/0.105 overload
ip nat inside source route-map isp2 interface GigabitEthernet0/0.233 overload i
thanks.
if i used the same name route-map how i apply this same route-map at nat???
  Just follow the document I provided. You should create a new route-map for NAT.
HTH,
Toshi
Hi Thotsaphon. i did configuration as you said me. I want to make both the links as back up of each other.In case of one of the link goes my all the traffic will use the other link. how i do that at this configuration?(HSRP config between two router and track outside interface).thanks
no ip address
duplex auto
speed auto
description connected to ISP1
ip address 85.x.x.108 255.255.255.248
ip nat outside
ip virtual-reassembly
description connected to ISP2
ip address 81.x.x.234 255.255.255.248
ip nat outside
ip nat inside
duplex auto
speed auto
standby 1 ip 10.0.0.3
standby 1 priority 110
standby 1 preempt
standby 1 track 1 decrement 20
ip forward-protocol nd
no ip http server
no ip http secure-server
ip nat inside source route-map ISP1 interface GigabitEthernet0/0.105 overload
ip nat inside source route-map ISP2 interface GigabitEthernet0/0.233 overload
ip route 0.0.0.0 0.0.0.0 85.x.x.110
ip route 0.0.0.0 0.0.0.0 81.x.x.233
set ip next-hop 85.x.x.110
set ip next-hop 81.x.x.233
route-map ISP2 permit 20
route-map ISP1 permit 10
