ASA cluster with VSS
Sun Flower
I have configured 2 ASA-5555 as a cluster, and 2 C4500-x as VSS in inside zone, and 2 C4500x as VSS in outside zone. When I verify ASA cluster and VSSs in both switches, the output shows Ok. I have attached topology.
When ASA1 is master, I can ping from outside host to inside post. But When ASA1 is failed and ASA2 becomes Master, I can't ping to the inside host. I can only to ASA outside interface, but can't ping to inside host when ASA1 failed and ASA2 becomes Master. (All related Inside, Outside configurations are done including NAT, ACL and ip route etc...)
I configured cluster and VSS configs according to Cisco documents. But it seems like not working well together VSS and Cluster. Please look through config and attached topology, and help me to find misconfiguration.
Here is the ASA cluster related configuration.
interface GigabitEthernet1/0
channel-group 10 mode on
no nameif
no security-level
no ip address
interface GigabitEthernet1/1
no nameif
no security-level
no ip address
interface GigabitEthernet1/2
description Inside
channel-group 3 mode active vss-id 2
no nameif
no security-level
no ip address
interface GigabitEthernet1/3
description Inside
channel-group 3 mode active vss-id 1
no nameif
no security-level
no ip address
interface GigabitEthernet1/4
description Outside
channel-group 1 mode active vss-id 2
no nameif
no security-level
no ip address
interface GigabitEthernet1/5
description Outside
channel-group 1 mode active vss-id 1
no nameif
no security-level
no ip address
interface Port-channel1
lacp max-bundle 8
port-channel span-cluster vss-load-balance
nameif Outside
security-level 10
ip address 10.1.1.1 255.255.255.0
interface Port-channel3
lacp max-bundle 8
nameif Inside
security-level 90
ip address 192.168.1.100 255.255.255.0
cluster group cluster1
key *****
local-unit unit-2
cluster-interface Port-channel10 ip 2.2.2.2 255.255.255.0
priority 2
health-check holdtime 3
clacp system-mac auto system-priority 1
enable
mtu cluster 9000
jumbo-frame reservation
Here is the Inside 4500x Switch configuration.
switch virtual domain 20
switch mode virtual
switch 1 priority 110
switch 2 priority 120
mac-address use-virtual
switchport
switchport access vlan 450
switchport mode access
interface Port-channel103
switchport
switchport mode trunk
switchport nonegotiate
switch virtual link 1
interface Port-channel104
switchport
switch virtual link 2
interface Port-channel11
switchport
interface Port-channel12
switchport
interface TenGigabitEthernet1/1/31
channel-group 11 mode on
interface TenGigabitEthernet1/1/32
channel-group 12 mode on
interface TenGigabitEthernet1/2/4
switchport trunk allowed vlan 450
interface TenGigabitEthernet1/2/5
no lldp transmit
no lldp receive
channel-group 103 mode on
service-policy output VSL-Queuing-Policy
interface TenGigabitEthernet1/2/6
no lldp transmit
no lldp receive
interface TenGigabitEthernet1/2/7
lacp rate fast
spanning-tree portfast edge
interface TenGigabitEthernet1/2/8
lacp rate fast
interface TenGigabitEthernet2/1/31
interface TenGigabitEthernet2/1/32
interface TenGigabitEthernet2/2/4
interface TenGigabitEthernet2/2/5
no lldp transmit
no lldp receive
no cdp enable
channel-group 104 mode on
interface TenGigabitEthernet2/2/6
no lldp transmit
no lldp receive
no cdp enable
interface TenGigabitEthernet2/2/7
lacp rate fast
interface TenGigabitEthernet2/2/8
lacp rate fast
interface Vlan450
ip address 192.168.1.101 255.255.255.0
Here is the Outside 4500x Switch configuration.
switch virtual domain 10
switch mode virtual
interface Port-channel32
ip address 10.1.1.2 255.255.255.0
interface Port-channel101
switchport
interface Port-channel102
switchport
no lldp transmit
no lldp receive
channel-group 101 mode on
no lldp transmit
no lldp receive
no switchport
no ip address
channel-group 32 mode active
no switchport
no ip address
no lldp transmit
no lldp receive
channel-group 102 mode on
no lldp transmit
no lldp receive
no switchport
no ip address
no switchport
no ip address
0 Replies 0
