ASA, DMZ Routing
Shuffle
EDIT:
To the new people who see this post here are the updates.
I need some help with my topology. I have 3 LANs in Australia (CBR, SYD, and MELB) and 2 international LANs (NY, and LDN). Each network has 3 VLANs, one for Native, one for Admin, and one for Receptionist (data). CBR, NY, and LDN should each have DMZs and any LAN should be able to ping the servers within the DMZs. However, the LANs are not supposed to ping each other. Also, my assignment only required an ASA firewall on CBR and the international LANs so didn't worry about the other two branch offices. I have set assess-lists to allow Outside to be able to ping the DMZ, but I'm not sure how to get a LAN with a firewall let's say, UK, to ping CBRs DMZ. I'm also not sure if there is a glitch in the Canberra network because the LAN can not ping its corresponding DMZ (Right now the LANs can only ping their corresponding DMZ like UK to UK DMZ, and US to US DMZ.) But first I need to figure out I can not ping internationally. Like UK to CBR. Or even SYD to CBR. It just doesn't work.
USERNAME: ADMIN PASSWORD: CISCO
PKT: https://drive.google.com/file/d/1xN4PBQEidxtBlF0jCwdHu-GIO0bp-YBl/view?usp=sharing
Here is the VLSM table.
Subnet Description
Public Network Address
Number of Host created
Subnet Mask
1st Public Usable Host Address
last Public Usable Host Address
Broadcast
Headquarters (CBR)
128.0.0.0
1022
255.255.252.0
128.0.0.1
128.0.3.254
128.0.3.255
Branch Office (SYD)
128.0.4.0
510
255.255.254.0
128.0.4.1
128.0.5.254
128.0.5.255
Branch Office (MEL)
128.0.6.0
510
255.255.254.0
128.0.6.1
128.0.7.254
128.0.7.255
Branch Office (LDN)
128.0.8.0
510
255.255.254.0
128.0.8.1
128.0.9.254
128.0.9.255
Branch Office (NY)
128.0.10.0
510
255.255.254.0
128.0.10.1
128.0.11.254
128.0.11.255
Admin (CBR)
128.0.12.0
126
255.255.255.128
128.0.12.1
128.0.12.126
128.0.12.127
Admin (SYD)
128.0.12.128
126
255.255.255.128
128.0.12.129
128.0.12.254
128.0.12.255
Admin (MELB)
128.0.13.0
126
255.255.255.128
128.0.13.1
128.0.13.126
128.0.13.127
Admin (LDN)
128.0.13.128
126
255.255.255.128
128.0.13.129
128.0.13.254
128.0.13.255
Admin (NY)
128.0.14.0
126
255.255.255.128
128.0.14.1
128.0.14.126
128.0.14.127
Reception (AU)
128.0.14.128
62
255.255.255.192
128.0.14.129
128.0.14.190
128.0.14.191
Reception (SYD)
128.0.14.192
62
255.255.255.192
128.0.14.193
128.0.14.254
128.0.14.255
Reception (MELB)
128.0.15.0
62
255.255.255.192
128.0.15.1
128.0.15.62
128.0.15.63
Reception (LDN)
128.0.15.64
62
255.255.255.192
128.0.15.65
128.0.15.126
128.0.15.127
Reception (NY)
128.0.15.128
62
255.255.255.192
128.0.15.129
128.0.15.190
128.0.15.191
DMZ (AU)
128.0.15.192
62
255.255.255.192
128.0.15.193
128.0.15.254
128.0.15.255
DMZ (LDN)
128.0.16.0
62
255.255.255.192
128.0.16.1
128.0.16.62
128.0.16.63
DMZ (NY)
128.0.16.64
62
255.255.255.192
128.0.16.65
128.0.16.126
128.0.16.127
ASA/Firewall
128.0.16.128
62
255.255.255.192
128.0.16.129
128.0.16.190
128.0.16.191
13 Replies 13
Hi @Shuffle
  On the file attached below, the hosts are able to ping the servers on the respective DMZs.  If I understood properly your requirement, this part is OK.
 Now, you can not isolate the LAN using the firewall because the traffic between LANs does not go to the firewall, as you have a Router between the LANs and the firewall. The only way a Firewall can filter traffic is if the traffic cross its interface.
 So, either you use Access List on the Router or you make the LAN traffic to cross the firewall.
Every LAN in the network should be able to ping any DMZ in the network. But right now, they can only ping their respective DMZ but should be able to ping the other DMZ's.
Like if I try to ping a PC from the UK to the WEB server in Australia's DMZ. It shows
You need to review your addressing map. You are using network 128.0.16.0/26  in different points of the network.
Use the most different addressing you can to make it easier to organize the routing. Overlaping  network will not work.
I've updated some ports to use 129.0.0.0/26 instead so I wouldn't overlap. However, I still can't ping, for example, UK to AUS.
https://drive.google.com/file/d/1mKvAl0giMHHEpov0hY2uB24iBY9e1ALh/view?usp=sharing
also Canberra's LAN can't ping it's respective DMZ. if you need, cbr asa's password is cisco. The other 2 doesn't have a password
You still have overlaps . Look the  IP address between Australia Firewall and router CBR_ISP is the same as the network netween UK firewall and UK_ISP
 As you are using dynamic routing protocol this turns you whole network in a flat network and averyone is suppose to know every network. If you have two equal network on the topology, you will create conflict on the routing table.
You need to use the network once and no more than once.
I tried to eliminate the most I could of overlaps network and I am able to png from AUS to DMZ, you may check this file.
 Hint. Prefer static routes on the ASA. It does not handle well OSPF.
Hey, any chance you could tell me what you configured? It's just that I've progressed with my project and I would rather implement what you did into my current one. Sorry for the hassle.
P.S I figured that OSPF was messing with the ASA firewall and switched it to static. Happy that it was the right decision
 I just replaced the network 192.168.1.0 that was configured between most of firewalls and router for something else.
As I said, as you are using OSPF everywhere, you cannot overlap the networks or you create conflict. Another good practive is enable defautl route on firewalls as they do not work very well with OSPF.
Ok, so I think I have done what you have been saying. But now the LAN PCs can't ping their respective DMZ; only their router can ping it. I still can't ping international DMZ for example UK to CBR. I've switched to static IPs on the ASA firewalls, added SSH, access list and groups, and fixed the UK and US DHCP. The username and password for the ASA firewall is: U - admin P - cisco.
https://drive.google.com/file/d/1JKpmEQcCAZAJySb_oETM6Hw6r9cIn1oP/view?usp=sharing
EDIT:
This example is the UK LAN to it's DMZ.
It pings sometimes but not all the time for some reason. I'm really about to pull my hair out haha. (This example only happens in the UK LAN. No where else)
Edit Edit: Does having 129.0.0.0 between the ASA and LAN router bad then? Do I have to have different networks for each?
If  you are going to use the static routing on the ASA, make sure you put all the entries necessary. Otherwise, keep working with OSPF.
OSPF works, but I see some problems sometimes. I fix the problem for you betweek LAN and DMZ. Take a look on th  firewalls  routes.
Ok so I did what you told me for all the firewalls, which does work except for the CBR LAN. Also, I'm still not able to ping international DMZs
