ASA routing protocols?
jroy777
Looking for recommendations for routing traffic from ASA back to router on "inside" network so we do not have to add static routes on systems. We recently added an ASR1001 to our "inside" network that routes traffic to Amazon thru a Megaport link that is established to AWS Direct Connect cloud. I add static routes to servers but we have a mix of equipment and I don't want to manually do this hundreds of times. The servers default route is the ASA, the ASA has a static route to the AWS networks back behind the ASR but none of the systems can reach it unless I specifically add the network to the routing table on the system. If I enable a routing protocol on the ASA, does anyone have an idea of the load increase it might add? Current we have a 5555 pair and processors runs consistently between 60 and 85%. If a routing protocol is feasible, which one would any of you recommend and why?
Thanks for your input!
20 Replies 20
check this
and ASA already connect to these three subnet DMZ Inside and UAT, so no need any eigrp
eigrp will use by ASA to reach the 169,254,38,181 subnet only
check the topolog I draw below and please answer the Q
MHM
From host 192.168.50.92 on inside (blue), no static routes added to host, I can ping 10.33.160.10, I can traceroute. All works correctly.
IPv4 Route Table
Active Routes:
Network Destination Netmask Gateway Interface Metric
0.0.0.0 0.0.0.0 192.168.50.1 192.168.50.92 276
127.0.0.0 255.0.0.0 On-link 127.0.0.1 306
127.0.0.1 255.255.255.255 On-link 127.0.0.1 306
127.255.255.255 255.255.255.255 On-link 127.0.0.1 306
192.168.50.0 255.255.254.0 On-link 192.168.50.92 276
192.168.50.92 255.255.255.255 On-link 192.168.50.92 276
192.168.51.255 255.255.255.255 On-link 192.168.50.92 276
224.0.0.0 240.0.0.0 On-link 127.0.0.1 306
224.0.0.0 240.0.0.0 On-link 192.168.50.92 276
255.255.255.255 255.255.255.255 On-link 127.0.0.1 306
255.255.255.255 255.255.255.255 On-link 192.168.50.92 276
Persistent Routes:
Network Address Netmask Gateway Address Metric
0.0.0.0 0.0.0.0 192.168.50.1 Default
C:\Users\jroy>ping 10.33.160.10
Pinging 10.33.160.10 with 32 bytes of data:
Reply from 10.33.160.10: bytes=32 time=37ms TTL=251
Ping statistics for 10.33.160.10:
Packets: Sent = 2, Received = 2, Lost = 0 (0% loss),
Approximate round trip times in milli-seconds:
Minimum = 37ms, Maximum = 37ms, Average = 37ms
Control-C
^C
C:\Users\jroy>tracert -d 10.33.160.10
Tracing route to 10.33.160.10 over a maximum of 30 hops
1 1 ms * 1 ms 192.168.50.1 <-ASA
2 2 ms 1 ms 1 ms 192.168.51.249 <-ASR
3 29 ms 29 ms 29 ms 169.254.38.181 <-AWS BGP neighbor
4 * * * Request timed out.
5 37 ms 36 ms 36 ms 10.33.160.10 <---Excellent
Trace complete.
C:\Users\jroy>
From host 10.1.1.90 on dmz (green), no static routes added to host, I CANNOT ping 10.33.160.10, I CANNOT traceroute.
IPv4 Route Table
Active Routes:
0.0.0.0 0.0.0.0 10.1.1.1 10.1.1.90 266
10.1.0.0 255.255.254.0 On-link 10.1.1.90 266
10.1.1.90 255.255.255.255 On-link 10.1.1.90 266
10.1.1.255 255.255.255.255 On-link 10.1.1.90 266
169.254.38.180 255.255.255.252 10.1.0.4 10.1.1.90 11
224.0.0.0 240.0.0.0 On-link 10.1.1.90 266
255.255.255.255 255.255.255.255 On-link 10.1.1.90 266
Persistent Routes:
0.0.0.0 0.0.0.0 10.1.1.1 Default
C:\Windows\system32>ipconfig
Windows IP Configuration
Ethernet adapter Ethernet 5:
Connection-specific DNS Suffix . :
IPv4 Address. . . . . . . . . . . : 10.1.1.90
Subnet Mask . . . . . . . . . . . : 255.255.254.0
Default Gateway . . . . . . . . . : 10.1.1.1
C:\Windows\system32>ping 10.33.160.10
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Packets: Sent = 4, Received = 0, Lost = 4 (100% loss),
C:\Windows\system32>tracert -d 10.33.160.10
1 <1 ms * <1 ms 10.1.1.1
2 <1 ms <1 ms <1 ms 65.203.136.1 <-2nd hop wrong path, going out ASA
3 * * ^C
From host 10.10.2.20 on uat (purple), no static routes added to host, I CANNOT ping 10.33.160.10, I CANNOT traceroute.
2nd hop is wrong path going out ASA
10.33.160.10 <<- this IP behind the ASA or ASR ?
I think I found the issue here but answer above Q and for my side I will run lab and check
MHM
10.33.160.10 is behind ASR in the AWS cloud. Was this the Q or did I miss another Q?
I had to add to an acl that is assigned to a route-map and then traffic started to flow in the correct direction for UAT and DMZ. Only one thing left. DMZ is still not getting a response to my ping. UAT works.
I added the following to the route-VZ acl assigned to the route-map
access-list route-VZ remark #### Avoid dmz traffic to route through outside VZ int ####
access-list route-VZ extended deny ip object DMZ object-group AWS-DC-MP-Subnets
access-list route-VZ remark #### Avoid UAT traffic to route through outside VZ int ####
access-list route-VZ extended deny ip object UAT_NET object-group AWS-DC-MP-Subnets
From host on UAT (vlan35) it is working.
C:\Windows\system32>route print
Interface List
 18...2a 74 5c 02 e8 28 ......XenServer PV Network Device #0
  1...........................Software Loopback Interface 1
 12...00 00 00 00 00 00 00 e0 Microsoft ISATAP Adapter
 13...00 00 00 00 00 00 00 e0 Teredo Tunneling Pseudo-Interface
IPv4 Route Table
Active Routes:
          0.0.0.0          0.0.0.0        10.10.2.1       10.10.2.20    266
        10.10.2.0    255.255.255.0         On-link        10.10.2.20    266
       10.10.2.20  255.255.255.255         On-link        10.10.2.20    266
      10.10.2.255  255.255.255.255         On-link        10.10.2.20    266
        224.0.0.0        240.0.0.0         On-link        10.10.2.20    266
  255.255.255.255  255.255.255.255         On-link        10.10.2.20    266
Persistent Routes:
          0.0.0.0          0.0.0.0       10.1.1.163  Default
          0.0.0.0          0.0.0.0        10.10.2.1  Default
IPv6 Route Table
Active Routes:
 If Metric Network Destination      Gateway
  1    306 ::1/128                  On-link
  1    306 ff00::/8                 On-link
Persistent Routes:
  None
Reply from 10.33.160.10: bytes=32 time=34ms TTL=251
    Minimum = 34ms, Maximum = 34ms, Average = 34ms
Control-C
^C
  1    <1 ms     *       <1 ms  10.10.2.1
  2    <1 ms    <1 ms    <1 ms  192.168.51.249
  3    29 ms    28 ms    28 ms  169.254.38.181
  5    34 ms    34 ms    34 ms  10.33.160.10
Trace complete.
From host on DMZ ping is not working but the traceroute shows it is taking the correct path
C:\Users\jroy>ipconfig
Tunnel adapter isatap.{C0D84F0E-B711-408F-8046-367A1D72E682}:
   Media State . . . . . . . . . . . : Media disconnected
Tunnel adapter Teredo Tunneling Pseudo-Interface:
C:\Users\jroy>route print
Interface List
 17...b2 8d 40 ac f8 02 ......XenServer PV Network Device #0
 16...00 00 00 00 00 00 00 e0 Teredo Tunneling Pseudo-Interface
IPv4 Route Table
Active Routes:
Persistent Routes:
IPv6 Route Table
Active Routes:
Persistent Routes:
  None
  3    28 ms    40 ms    28 ms  169.254.38.181
  5     *        *        *     Request timed out.
  6     *        *        *     Request timed out.
  7     *        *        *     Request timed out.
  8     *        *        *     Request timed out.
  9     *        *        *     Request timed out.
 10     *        *        *     Request timed out.
 11     *        *        *     Request timed out.
 12     *        *        *     Request timed out.
 13     *        *        *     Request timed out.
 14     *        *        *     Request timed out.
 15     *        *        *     Request timed out.
 16     *        *        *     Request timed out.
 17     *        *        *     Request timed out.
 18     *        *        *     Request timed out.
 19     *        *        *     Request timed out.
 20     *        *        *     Request timed out.
 21     *        *        *     Request timed out.
 22     *        *        *     Request timed out.
 23     *        *        *     Request timed out.
 24     *        *        *     Request timed out.
 25     *        *        *     Request timed out.
 26     *        *        *     Request timed out.
 27     *        *        *     Request timed out.
 28     *        *        *     Request timed out.
 29     *        *        *     Request timed out.
 30     *        *        *     Request timed out.
Trace complete.
Request timed out.
Request timed out.
    Packets: Sent = 2, Received = 0, Lost = 2 (100% loss),
Control-C
^C
I think I know what it is. They may have not added a return path back to 10.10.2.0/24 in the AWS cloud
