ASA subinterfaces and switch
lubosbella
Level 3
Level 3
i want to ask:
I need to divide my Outside ASA interface to subinterfaces like this (VPN will be terminatedon subinterfaces):
interface GigabitEthernet0/0
interface GigabitEthernet0/0.1
nameif Outside
security-level 0
ip address 117.x.x.x 255.255.255.224
vlan 30
interface GigabitEthernet0/0.2
nameif Outside2
security-level 0
ip address 118.x.x.x 255.255.255.248
vlan 40
Physical interface gigabitEthernet0/0 will be connected to cisco switch (because there are two ASA´s in active-standby configuration we need cable to primary,secondary ASA) and from switch to ISP router.
How to configure this switch? Should I configure conected interfaces to trunk all vlans?
Is this configuration sufficient and good or not?
hostname Switch
no aaa new-model
system mtu routing 1500
ip subnet-zero
no file verify auto
spanning-tree mode pvst
vlan internal allocation policy ascending
interface GigabitEthernet0/1
description To_ASA1
switchport mode trunk
interface GigabitEthernet0/2
description To_ASA2
interface GigabitEthernet0/3
interface GigabitEthernet0/4
interface GigabitEthernet0/5
interface GigabitEthernet0/6
interface GigabitEthernet0/7
interface GigabitEthernet0/8
interface GigabitEthernet0/9
interface GigabitEthernet0/10
description To_ISP
interface GigabitEthernet0/11
interface GigabitEthernet0/12
interface GigabitEthernet0/13
interface GigabitEthernet0/14
interface GigabitEthernet0/15
interface GigabitEthernet0/16
interface GigabitEthernet0/17
interface GigabitEthernet0/18
interface GigabitEthernet0/19
interface GigabitEthernet0/20
interface GigabitEthernet0/21
interface GigabitEthernet0/22
interface GigabitEthernet0/23
interface GigabitEthernet0/24
interface GigabitEthernet0/25
interface GigabitEthernet0/26
interface GigabitEthernet0/27
interface GigabitEthernet0/28
interface Vlan1
no ip address
shutdown
interface Vlan30
no ip address
interface Vlan40
no ip address
ip classless
ip http server
control-plane
line con 0
line vty 5 15
end
Thank for any advice.
nickhesson
Level 4
Level 4
Not knowing what your end goal is, are you trying to connect to two different ISP's, or one ISP via two different LAN blocks?  The latter case is pointless in terms for redundancy.  I believe its a 5510, or higher.  So your subinterfaces and you switchport configuration looks correct.  The only thing that looks off, again because not knowing what your trying to do.  Your truck connection to the ISP router.  It's not normal to see an ISP router have two different LAN blocks on two different vlans.  But that is just guessing the case from the above config.
Hope that helps,
Nick
yes it´s ASA 5520.
We have two links to Internet - from the same ISP. Capacity of first connection is 10Mbit/s and second 12Mbit/s . We want to use both links - first to internet browsing, mail etc. second for VPN connection from other company.
Our ISP merge this two link in their router (they will be balanced links that capacity is not zero if one of the link fail - its a ISP job so not interestig to my question) and from ISP router one physical interface divided to subinterfaces will be connected to our ASA´s. Between our ASA´s and router is one switch that split physical connection because of active/standby configuration.
Maybe a picture is better to understand.
Thanks.
