ASA VPN Configuration
welaish77
When i connect the client says lan Access is disabled and the check box in the client is checked but i am not able to ping any server in the lan. below is the ASA configuration.
ASA Version 7.0(6)
hostname HCASA
domain-name default.domain.invalid
enable password NjVk0ak/KEllGQF7 encrypted
names
name 172.19.134.34 i_ibrahim
name 172.19.134.35 i_wael
dns-guard
interface Ethernet0/0
nameif outside
security-level 0
ip address 83.111.190.178 255.255.255.240
interface Ethernet0/1
nameif inside
security-level 100
ip address 172.19.134.22 255.255.255.0
interface Ethernet0/2
shutdown
no nameif
no security-level
no ip address
interface Ethernet0/3
shutdown
no nameif
no security-level
no ip address
interface Management0/0
nameif management
security-level 100
no ip address
management-only
passwd NjVk0ak/KEllGQF7 encrypted
ftp mode passive
dns domain-lookup outside
dns name-server 213.42.20.20
access-list acl_out extended permit icmp any any
access-list Local_LAN_Access remark VPN Client Local LAN Access
access-list Local_LAN_Access standard permit host 0.0.0.0
pager lines 24
logging asdm informational
mtu outside 1500
mtu inside 1500
mtu management 1500
ip local pool vpnpool 172.19.134.61-172.19.134.70 mask 255.255.255.0
no failover
asdm image disk0:/asdm506.bin
no asdm history enable
arp timeout 14400
global (outside) 1 interface
nat (inside) 1 172.19.134.0 255.255.255.0
access-group acl_out in interface outside
route outside 0.0.0.0 0.0.0.0 83.111.191.177 1
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00
timeout mgcp-pat 0:05:00 sip 0:30:00 sip_media 0:02:00
timeout uauth 0:05:00 absolute
group-policy afhcvpn internal
group-policy afhcvpn attributes
dns-server value 172.19.134.2
vpn-tunnel-protocol IPSec
split-tunnel-policy excludespecified
split-tunnel-network-list value Local_LAN_Access
default-domain value test.com
webvpn
username username password password encrypted privilege 15
http server enable
http i_wael 255.255.255.255 inside
http 172.19.134.0 255.255.255.0 management
no snmp-server location
no snmp-server contact
snmp-server enable traps snmp authentication linkup linkdown coldstart
crypto ipsec transform-set esp-3des-sha esp-3des esp-sha-hmac
crypto dynamic-map outside_dyn_map 10 set transform-set esp-3des-sha
crypto dynamic-map outside_dyn_map 10 set security-association lifetime seconds
288000
crypto dynamic-map outside_dyn_map 10 set reverse-route
crypto map outside_map 10 ipsec-isakmp dynamic outside_dyn_map
crypto map outside_map interface outside
isakmp enable outside
isakmp policy 1 authentication pre-share
isakmp policy 1 encryption 3des
isakmp policy 1 hash sha
isakmp policy 1 group 2
isakmp policy 1 lifetime 43200
isakmp nat-traversal 20
tunnel-group afhcvpn type ipsec-ra
tunnel-group afhcvpn general-attributes
address-pool vpnpool
tunnel-group afhcvpn ipsec-attributes
pre-shared-key *
telnet i_wael 255.255.255.255 inside
telnet i_ibrahim 255.255.255.255 inside
telnet timeout 5
ssh timeout 5
console timeout 0
dhcpd lease 3600
dhcpd ping_timeout 50
class-map inspection_default
match default-inspection-traffic
policy-map global_policy
class inspection_default
inspect dns maximum-length 512
inspect ftp
inspect h323 h225
inspect h323 ras
inspect rsh
inspect rtsp
inspect esmtp
inspect sqlnet
inspect skinny
inspect sunrpc
inspect xdmcp
inspect sip
inspect netbios
inspect tftp
service-policy global_policy global
Cryptochecksum:55672133bd1911826fe2d31b2a360b0e
HCASA#
if you are configuring throught ASDM,go to security policy & access rule.
here are the steps
Source/host or network -----any
Dest/host or network -----Inside ip address
Rule Applied to traffic-----incomin
Interface Outbound -----Outside
Service -----HTTPS,TCP,UDP
7 Replies 7
sibgathullah
Dear,
Where are the access-list ?
what access-list command i should issue?
Just mention an access-list for your server, then try it as i have got the same thing in my network n as i have given access-list according to the servers ip n it working.
rgds
!!!! Actually i dont understand what server are you talking about? simply i need people to connect to the ASA VPN and do remote desktop on their machines. so they need to access the local lan. which they cannot do.
You have to specify the access-list according to the IP's or server's you wanna access from out,and give the permission...It will work.As i have specified according to the IP and given the Allow Access-list n its working.
give me an example i want them to access the whole internal lan.
thanks
here are the steps
