ASA VPN issue
sprocket10
Level 2
Level 2
I am having an issue setting up a new sites ASA, the VPN tunnel comes up but i just cant ping anything across it. I have done the usual checks, nat rules etc but just cant see the problem. I have even wiped the ASA and copied the config from a working sites ASA onto this one, changed IPs etc and still tunnels come straight up and no traffic.
I just cant see the problem, probably obvious but i have been looking to long.
Richard Burts
You have told us that it is not working and have given us very little to work with to find the problem. A good place to start would be to post configurations (probably need both sides).
Rick
Rick
sprocket10
Level 2
Level 2
Resolution was MTU settings on the WAN interface.
Thank you for posting back to the forum and letting us know that you have solved it and what the issue was. That may be helpful to some other reader who may have a similar problem at some time.
Rick
Rick
