asr-1000
Ibrahim Jamil
Level 6
Level 6
Hi Experts
i have asr 1004 sip 10 ,i only have single esp and single rp, now how can i verify it has 2 IOS for boot if one of these two corrupted?
can u lead me to learn how to perform ISSU for this box?
thanks
jamil
7 Replies 7
Ivan Shirshin
Hi Jamil,
Do you mean 2 images to boot the router from or redundant IOS process?
In first case you have to load both image on one of the router file systems and configure 2 "boot system" commands.
      boot system flash bootflash:file1.bin
      boot system flash bootflash:file2.bin
You can check for current config with "show boot" or "show run | i boot".
In case of standby IOS process, please see the following guide:
http://www.cisco.com/en/US/docs/routers/asr1000/configuration/guide/chassis/issu.html#wp1158739
In regards to ISSU - non-hardware-redundant chassis models (such as the  Cisco ASR 1001 Router, Cisco ASR 1002 Router and Cisco ASR 1004 Router)  do not support ISSU upgrade or downgrade. Instead subpackage software  upgrade is supported only if the router is running in subpackage  mode.Traffic loss cannot be avoided during the installation of the ESP  package as a part of ISSU.
Kind Regards,
Ivan
**Please grade this post if you find it useful.
Kind Regards,
Ivan
Hi Ivan
thanks for ur reply
i have been told my box has double boot , double ios ! how can i check that?
thanks
jamil
Kindly post the output to the command "dir".
Hi freind
Directory of bootflash:/
   11  drwx       16384  Jan 11 2011 07:11:16 +00:00  lost+found
   12  -rw-   273273136  Jan 11 2011 07:12:28 +00:00  asr1000rp1-adventerprise.03.01.00.S-1.S.bin
58625  drwx        4096  Jan 11 2011 07:13:03 +00:00  .installer
43969  drwx        4096  Mar 27 2012 03:36:00 +00:00  .prst_sync
73281  drwx        4096  Jan 11 2011 07:42:01 +00:00  .rollback_timer
Ibrahim,
you got only 1 image " asr1000rp1-adventerprise.03.01.00.S-1.S.bin". If you want to add another one then you need to copy from tftp to the flash etc and change the boot order if you want the new IOS to be active as indicated by Ivan
Kishore
Kishore is right.  There's only ONE (1) IOS there.  You can add a few IOS in there as long as the bootflash has enough space for them.
thanks guys, HOW Can i become expert in these asr?y know this device from cisco is totaly different other than devices. since this IOS-XE is 200MBy
