ASR 1001 HIGH DELAY WITH SHOW IP CACHE FLOW COMMAND
HI,
We recently have changed a 7206VXR router with NPE-10G processor with a ASR 1001.
This ASR 1001 router have the following specification:
System restarted at 16:12:46 UTC Wed Feb 27 2013
System image file is "bootflash:/asr1001-universalk9.03.06.00.S.152-2.S.bin"
Last reload reason: Reload Command
Next reload license Level: adventerprise
cisco ASR1001 (1RU) processor with 1163580K/6147K bytes of memory.
Processor board ID SSI163204CZ
4 Gigabit Ethernet interfaces
32768K bytes of non-volatile configuration memory.
4194304K bytes of physical memory.
7741439K bytes of eUSB flash at bootflash:.
SITEL_CHICHON#
the problem we have with this router is thet when we excute the command: show ip cache flow | include 10.41.238.x the ressults delay to appear more than 2 minutes.
Can you tell me if this high delay to show me the results is normal?
Attn.
Roger
Greetings.
how much CPU usage you had on that router ??? [show process cpu hist]
Just to know if your CPU had an peak of usage that produce the high delay ....
had a great day . best regards, and rate if you'll find this post useful
