ASR 1001 IOS-XE And ROMMON Upgrade
MilanVerma17
Hello All,
We need to upgrade IOS from IOS XE 03.06.00.S to 3.16.10S MD and ROMMON to 15.5.(3r)S1.
It would be very helpful if you could share step by step process for it.
ASR1001#sh version
Cisco IOS Software, IOS-XE Software (X86_64_LINUX_IOSD-UNIVERSALK9-M), Version 15.2(2)S, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2012 by Cisco Systems, Inc.
Compiled Mon 26-Mar-12 16:23 by mcpre
IOS XE Version: 03.06.00.S
Cisco IOS-XE software, Copyright (c) 2005-2012 by cisco Systems, Inc.
All rights reserved. Certain components of Cisco IOS-XE software are
licensed under the GNU General Public License ("GPL") Version 2.0. The
software code licensed under GPL Version 2.0 is free software that comes
with ABSOLUTELY NO WARRANTY. You can redistribute and/or modify such
GPL code under the terms of GPL Version 2.0. For more details, see the
documentation or "License Notice" file accompanying the IOS-XE software,
or the applicable URL provided on the flyer accompanying the IOS-XE
software.
ROM: IOS-XE ROMMON
 ASR1001 uptime is 8 years, 19 weeks, 2 days, 15 hours, 23 minutes
Uptime for this control processor is 8 years, 19 weeks, 2 days, 15 hours, 24 minutes
System returned to ROM by reload
System restarted at 07:43:45 PST Sat Mar 9 2013
System image file is "bootflash:/asr1001-universalk9.03.06.00.S.152-2.S.bin"
Last reload reason: PowerOn
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
License Level: adventerprise
License Type: Permanent
Next reload license Level: adventerprise
cisco ASR1001 (1RU) processor with 1163580K/6147K bytes of memory.
Processor board ID SSI16300890
4 Gigabit Ethernet interfaces
32768K bytes of non-volatile configuration memory.
4194304K bytes of physical memory.
7741439K bytes of eUSB flash at bootflash:.
