ASR 1001-x 10GE port license
net.curious
I need your advise if anyone know.
I have an ASR 1001-x router with the default 2,5Gbps throughput.
I need to use the build-in 10GE interfaces. Do i need to buy a new license from Cisco or Not?
write now i have enabled:
#show license all | b StoreIndex: 13
StoreIndex: 13  Feature: interface_10g                     Version: 1.0
        License Type: EvalRightToUse
        License State: Active, In Use
            Evaluation total period: 8  weeks 4  days
            Evaluation period left: 7  weeks 4  days
            Period used: 6  days 1  hour
            Transition date: Mar 17 2018 16:45:34
        License Count: 1/0  (In-use/Violation)
        License Priority: Low
Router# show license feature
Feature name             Enforcement  Evaluation  Subscription   Enabled  RightToUse
adventerprise            yes          yes         no             no       yes
advipservices            yes          yes         no             yes      yes
ipbase                   no           no          no             no       no
avc                      yes          yes         no             no       yes
broadband                no           no          no             no       no
broadband_4k             no           no          no             no       no
cube_250                 no           no          no             no       no
cube_250_red             no           no          no             no       no
cube_ent_100             no           no          no             no       no
cube_ent_100_red         no           no          no             no       no
cube_lab                 no           no          no             no       no
cube_video_b2btp         no           no          no             no       no
cube_video_b2btp_red     no           no          no             no       no
firewall                 no           no          no             no       no
fpi                      no           no          no             no       no
fwnat_red                yes          yes         no             no       yes
gtp_addon_aic            no           no          no             no       no
internal_service         yes          no          no             no       no
ipsec                    yes          yes         no             no       yes
lawful_intr              yes          yes         no             no       yes
lisp                     yes          yes         no             no       yes
nat64_stateful_2m        no           no          no             no       no
otv                      yes          yes         no             no       yes
sgt_fw                   no           no          no             no       no
sw_redundancy            yes          yes         no             no       yes
throughput_5g            yes          yes         no             no       yes
throughput_5g_to_10g     yes          no          no             no       no
throughput_5g_to_20g     yes          no          no             no       no
throughput_10g           yes          yes         no             no       yes
throughput_10g_to_20g    yes          no          no             no       no
throughput_20g           yes          yes         no             no       yes
vpls                     yes          yes         no             no       yes
interface_10g            yes          yes         no             yes      yes
Router# show run | b
license boot level advipservices
Mark Malone
Giuseppe Larosa
according to the output that you have provided you need a license because you are using an evaluation license that will expire on March 17th 2018
And
I had to do the same on a Me-3600-X that was missing the licence to use the 2 x 10 GE uplink module.
You need to go to the licensing portal and to buy it.
If you are the end customer and you have bought the router via a Cisco partner or reseller you need to ask them to buy it for you and to provide the license.
You can use the following URL if you have the smartnet of the router
https://www.cisco.com/go/license
this will redirect you to the licensing portal. You need a CCO account with associated the smartnet or other support contract for the specific router involved.
Hope to help
Giuseppe
Mark Malone
This may help someone asked this the other week Cisco guy responded
https://supportforums.cisco.com/t5/lan-switching-and-routing/asr1001-x-licensing/td-p/3307657
