ASR 1002 rommon upgrade issue
Falcon1651
Hi to all,
I need advice how issue with rommon upgrade on our ASR 1002 device can be resolved.
Issue:
We tried to upgrade IOS on our ASR device by upgrading firstly rommon and then IOS.
After upgrading rommon, route processor remained with old rommon.
We have done this IOS ASR upgrade twice without any issues on similar devices.
We are using ATT lab approved versions of software:
- asr1000rp1-adventerprisek9.V151_3_S2_SR617255895_2.bin
- asr1000-rommon.150-1r.S.pkg
Current running IOS on ASR device:
asr1000rp1-advipservicesk9.02.06.00.122-33.XNF.bin
We tried also upgrading just route processor with same result (R0 08011017 12.2(33r)XNC):
r1#sh platform
Chassis type: ASR1002
Slot      Type                State                 Insert time (ago)
0         ASR1002-SIP10       ok                    2d01h
 0/0      4XGE-BUILT-IN       ok                    2d01h
 0/1      SPA-2X1GE-V2        ok                    2d01h
R0        ASR1002-RP1         ok, active            2d01h
F0        ASR1000-ESP5        ok, active            2d01h
P0        ASR1002-PWR-AC      ok                    2d01h
P1        ASR1002-PWR-AC      ok                    2d01h
Slot      CPLD Version        Firmware Version
0         07120202            15.0(1r)S
F0        07091401            15.0(1r)S
HW used:
r1#sh inv
NAME: "Chassis", DESCR: "Cisco ASR1002 Chassis"
PID: ASR1002           , VID: V02, SN: FOX1402G3YX
NAME: "module F0", DESCR: "Cisco ASR1000 Embedded Services Processor, 5Gbps"
PID: ASR1000-ESP5      , VID: V02, SN: JAE14110DV9
NAME: "Power Supply Module 0", DESCR: "Cisco ASR1002 AC Power Supply"
PID: ASR1002-PWR-AC    , VID: V01, SN: ART1403U05J
NAME: "Power Supply Module 1", DESCR: "Cisco ASR1002 AC Power Supply"
PID: ASR1002-PWR-AC    , VID: V01, SN: ART1404U050
NAME: "module 0", DESCR: "Cisco ASR1002 SPA Interface Processor 10"
PID: ASR1002-SIP10     , VID: V02, SN: JAE14110OM6
NAME: "SPA subslot 0/1", DESCR: "2-port Gigabit Ethernet Shared Port Adapter"
PID: SPA-2X1GE-V2      , VID: V01, SN: SAL16127T9E
NAME: "subslot 0/1 transceiver 0", DESCR: "GE SX"
PID: SFP-GE-S            , VID: 06  , SN: AGM1620P1R1
NAME: "subslot 0/1 transceiver 1", DESCR: "GE T"
PID: N/A                 , VID: E   , SN: MTC16160BV3
NAME: "SPA subslot 0/0", DESCR: "4-port Gigabit Ethernet Shared Port Adapter"
PID: 4XGE-BUILT-IN     , VID: V00, SN: N/A
NAME: "subslot 0/0 transceiver 0", DESCR: "GE T"
PID: N/A                 , VID: E   , SN: MTC1347042S
NAME: "subslot 0/0 transceiver 1", DESCR: "GE T"
PID: N/A                 , VID: E   , SN: MTC134704EK
NAME: "subslot 0/0 transceiver 2", DESCR: "GE T"
PID: N/A                 , VID: E   , SN: MTC1525049K
NAME: "subslot 0/0 transceiver 3", DESCR: "GE T"
PID: N/A                 , VID: E   , SN: MTC16160DV8
NAME: "module R0", DESCR: "Cisco ASR1002 Route Processor 1"
PID: ASR1002-RP1       , VID: V02, SN: JAE141200L8
I have not found any similar issue so I would really appreciate any kind of advice.
Leo Laohoo
The command to upgrade the ROMmon on an ASR is upgrade rom-monitor filename flash:blah.bin all.
Thanks for reply.
I used upgrade rom-monitor filename bootflash:asr1000-rommon.150-1r.S.pkg all
and I also did this separately for RP - R0.
But ASR returns common message:
ROMMON upgrade complete.
But the result was RP still on 12.2(33r)XNC.
