ASR 1002 settings for management vrf
Nikolay_Savin
I have ASR 1002F ios version 15.1
Now he connected to network only with Management interface Gig0
I need a features for management vrf Mgmt-intf, dns, syslog, tacacs, snmp-traps, ntp.
The settings I did in accordance with article
http://www.cisco.com/en/US/docs/routers/asr1000/configuration/guide/chassis/Management_Ethernet.html#wp1059079
Gateway default is working fine
ntp server is working too
but DNS not working
the settings for DNS
ip domain name vrf Mgmt-intf ad.root
ip name-server vrf Mgmt-intf 10.1.1.132
ip name-server vrf Mgmt-intf 10.1.1.145
ip name-server vrf Mgmt-intf 10.1.1.146
to check i used command
Router#ping vrf Mgmt-intf ad.root
Translating "ad.root"...domain server (255.255.255.255)
% Unrecognized host or address, or protocol not running.
Which setting need to working DNS?
0 Replies 0
