ASR 1002-X inner/outer VLAN config
madcatbb
Any know the command to set a outer vlan tag that is different than the inner vlan. Similar to a secondary VLAN tag but that command isn't available? Similar to below but secondary isn't an option.
interface GigabitEthernet0/0/0.2
encapsulation dot1Q 2 secondary 444
ip address 10.X.X.X 255.Y.Y.Y
Reza Sharifi
That command is not supported on the ASR1002x series.  I think it is supported on the 10000 series that supports PPPoE
see link:
http://www.cisco.com/en/US/docs/ios/lanswitch/configuration/guide/lsw_ieee_802.1q.html
What command on ASR1002-X does support inner/outer VLAN tags?
madcatbb
