ASR 1004 router bridge group bug and distribute-list bug
hitchij
We have encountered a couple of problems ASR1004 routers being deployed.
1/ When a bridge group is configured on a Fastethernet port the ASR outputs error:
*Nov 17 10:12:45.802: %TBRIDGE-4-INVALIDMEDIA: IEEE_STP received on FastEthernet 0/0/3 - invalid media for transparent bridging
This has been recreated in the lab using both the first extended IOS XE image 02.04.01 and also the first extended update 02.04.02
2/ On image version 02.04.01 it has also been noticed that a routing protocol distribute-list for a RIP interface does not work until the router is rebooted; same for a change to the vty exec command
Has anyone else experienced similar with these IOS XE images and raised a TAC case for a resolution? Thanks in advance.
xabrouck
Reg 1/ Bridge groups are not supported on ASR1k.
Reg 2/ Fabrice solved this already in the TAC SR you opened
thanks,
Xavier
