ASR 1013 log in
Hello All
Is there a command to login into line cards-slots  in Cisco ASR 1013 ? For ex. i want to connect  slot 0 ?
i have this output ;
Chassis type: ASR1013
Slot Type State Insert time (ago)
0 ASR1000-2T+20X1GE ok 4w6d
0/0 BUILT-IN-2T+20X1GE ok 4w6d
2 ASR1000-6TGE ok 4w6d
2/0 BUILT-IN-6TGE ok 4w6d
3 ASR1000-6TGE ok 4w6d
3/0 BUILT-IN-6TGE ok 3w0d
4 ASR1000-SIP40 ok 4w6d
4/0 SPA-1X10GE-L-V2 ok 4w6d
R0 ASR1000-RP2 ok, active 4w6d
R1 ASR1000-RP2 ok, standby 4w6d
F0 ASR1000-ESP100 ok, active 4w6d
F1 ASR1000-ESP100 ok, standby 4w6d
P0 ASR1013/06-PWR-AC ok 4w6d
P1 ASR1013/06-PWR-AC ok 4w6d
P2 ASR1013/06-PWR-AC ok 4w6d
P3 ASR1013/06-PWR-AC ok 4w6d
Ganesh Hariharan
Hello ,
Normally in Cisco 6500 series while logging on FWSM we issue command
session slot number processor 1
But with ASR , I never tried but you can give a try and see what is the result.
Hope it Helps..
-GI
Ganesh Hariharan
Hello ,
Hope it Helps..
-GI
Vinit Jain
Yes, you can enter into the line cards but remember that you can only get shell access to the router which is generally used by Cisco TAC for troubleshooting purposes.
to enable shell mode, Configure "platform shell" command
R1(config)#platform shell
Once you have enabled the platform shell, you can not enter the shell mode using the below command:
R1#request platform software system shell ?
  0   SPA-Inter-Processor slot 0
  1   SPA-Inter-Processor slot 1
  F0  Embedded-Service-Processor slot 0
  F1  Embedded-Service-Processor slot 1
  FP  Embedded-Service-Processor
  R0  Route-Processor slot 0
  R1  Route-Processor slot 1
  RP  Route-Processor
R1#request platform software system shell R0
Are you sure you want to continue? [y/n] y
R1_RP_0:/]$
To connect the slot 0, you can use just 0 instead of R0.
Hope this helps.
Vinit
--Vinit
