ASR light levels.
bellah123
What is the command on an ASR to get the optical light levels?
acampbell
try this but use your own subslot
This one is looking at 0/2/0
show hw-module subslot 0/2 transceiver 0 status
Outputs
MYROUTER#show hw-module subslot 0/2 transceiver 0 status
The Transceiver in slot 0 subslot 2 port 0 is enabled.
Module temperature = 32.355 C
Transceiver Tx bias current = 49342 uAmps
Transceiver Tx power = -2.3 dBm
Transceiver Rx optical power = -5.7 dBm
Regards, Alex. Please rate useful posts.
acampbell
Outputs
Thanks for your response @acampbell!
Finding the answer here saved me from having to dig through documentation.
vrs
fracjackmac
Thanks for asking the question @bellah123!
Finding the answer below saved me from having to dig through documentation.
vrs
