ASR port not going up with 100 Mb
Arup Dutta
Hi All,
I have one ASR 1002 router and one GSR router. when i insert  SFP-OC48-IR1 module with GSR and connect 100 Mb link
that comming from MUX then the GSR port is up but when the link is connect with ASR with same module the port not going up.
i had cross check the module GSR to ASR but the problem remain same.
please help me out of this problem
Rgd,
Arup
Giuseppe Larosa
Hello Arup,
what are you trying to achieve?
the SFP-OC48-IR1 should expect a 2,4 Gbps link in SONET or SDH technology so I don't see how you can connect it to a 100 Mbps link that might be probably ethernet based. if so you need a LAN port.
Hope to help
Giuseppe
